Question about KitchenAid KUDM01FK Dishwasher
Clean light keeps blinking on my kitchenaid dishwasher model # KUDM01FK
  • 25 Answers
SOURCE: Blinking Clean Light
  • Close dishwasher door
  • press "Hi-Temp Wash"
  • press "Energy Saver Dry"
run the 'normal' cycle without the hi temp feature
Posted on Jan 23, 2009
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
It says in the manual to check the heating element.
Posted on Sep 10, 2008
  • 188 Answers
SOURCE: Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Feb 20, 2009
  • 530 Answers
SOURCE: whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Posted on Apr 14, 2009
HOW TO RESET THE CONTROL PANEL ON KUDE60HXSS4
My Kitchen Aide Dishwasher KUDE60HXSS4 has the clean light blinking and water is coming out of the dishwasher running down the back wall. The dishwasher will not come on. The clean light just blinks.
Jul 11, 2012 | KitchenAid Architect® KUDT03FT 24 in...
Advice on removing upper rack needed thx
you may want to refer to the assembly diagram and see how the wheels and tracks are aligned. This should help you guide the rack out of the track.
Good luck.
May 13, 2011 | KitchenAid KUDM01FK Dishwasher
The clean light keeps blinking and the dishwasher will not turn on. have tried to push cancel which makes the clean light blink faster.
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light keeps blinking and washer will not function. Cancel runs the pump for 2 minute, but the blinking light keeps going with no functions working.
if the clean light is blinking that mean you dishwasher is having a heater issue. it is an error code. either your control board is bad or the heater or the ntc therm. if you take the bottom panel off you will see or should see a tech sheet that will tell you how to clear the error code or this website will help you. just enter your model number http://servicematters.com/docs/wiring/wiring_main.htm
Jul 03, 2010 | KitchenAid Dishwashers
The dishwasher will not Start and the Clean Light keeps blinking
This blinking indicates the water did not heat up properly in the heated wash part of the cycle. I have put together some instructions on resetting the control so you can use the machine and some details on why it might have happened. Follow the link and if you have any trouble let me know.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 03, 2010 | KitchenAid 24 in. KUDP02CRBS Stainless...
Kitchenaid dishwasher model kuds01
you have a water heating problem. there is a tech sheet taped to the inside of the toe plate
Dec 31, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140, THE DISHWASHER IS NOT RESPONDING TO ANY COMMANDS, THE RINSE LIGHT IS BLINKING AND THAT...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140. The unit is not drying the dishes?
Oct 02, 2009 | KitchenAid Dishwashers
Kitchenaid KUDS01FLBL2 dishwasher will not run
Juan, I found this http://fixitnow.com/wp/2007/01/20/blinking-clean-light-on-whirlpool-built-dishwashers/
It should help you out with the issue you are having with your dishwasher. Watch the video too!
Best of luck
Feb 25, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Nov 16, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Model # DU1055XTPQ3 WHIRPOOL DISHWASHER RESET CODE
chris72 had the solution to my Whirlpool DU1055XTPQ3 not turning on. Per Chris's suggestion, I pressed back and forth between sani rinse and heated dry. All the lights came on as it reset and it was good to go. The dishwasher started up immediately. Saved me a service call, THANK YOU Chris!!
Aug 07, 2008 | Whirlpool 24 in. DU920PW Built-In...
KitchenAid KUDM01FK Dishwasher Logo
105 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
