Question about Toshiba SD-6000
I don't have the installation instructions and need to know how to connect the cables to the DVD player and the TV. The remote does not work either. It has new batteries.
SOURCE: Toshiba Tv remote control
I NEED THE CODEOR CODES THAT TOSHIBA DVD-HD A30KU TU USE AND RECCEIVER ONKOY
Posted on Sep 24, 2008
SOURCE: Audiosonic DVD player no sound
Try using a diferent rf cables.I would suggest that red,white and yellow colour coded RF cable is still the best.(yellow for Pictuer,White for sound and red also for sound(surround).
had similar problem than i cahnge the cables and found out that it worked with that cable...
thanx,
FIJI
Posted on Nov 27, 2008
  • 3 Answers
SOURCE: hooking up my dvd player
Try an "RF Modulator". It can take in multiple type signals like your cable and dvd and send it to the TV via the coax. The one I have will take in Coax (cable), RCA (left, right & Video) and S-video.
Posted on Dec 26, 2008
daniel719
  • 240 Answers
SOURCE: tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Posted on Jan 11, 2009
SOURCE: having trouble setting up dvd/vcr
Slide down the cover on remote control.On the bottom right side you'll see a little switch(usually is cowered with the warning white little sticker).Slide that switch to DVD1(or DVD2 if somebody got different setting).Power up DVD/VCR combo press system menu botton,go to settings,change to DVD3(factory default)and there you go.Good luck.
Rich
Posted on Apr 11, 2009
I PURCHASED A MAGNAVOX Z V 427MG9 A VHS DVD RECORDER.I HAVE A NEW VIZIO VW26L HDTV. HOW DO I CONNECT THEM? I HAVE ALREADY CONNECTED A HDMI CABLE TO IT BUT DON'T KNOW TO SET IT UP. DO I NEED ANY OTHER...
HDMI cables are actually wonderfully simple to connect. Once you have connected one end to the TV and one end to the DVD player, you will simply need to change your input channel using your TV's remote. Find a Input or Video source button and press it until the screen says HDMI. Now your TV may have several HDMI ports so you may have to try a couple HDMI channels before you find the right one.
Hope that helps!
Jul 19, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
How to install a video machine if I don't have the tv remote?
I'm assuming by "video machine" you mean some kind of DVD player or Blu-ray player or something of the like. I will explain how to install a DVD player. There are two major cables: one sends the video to the TV and the other sends power to the DVD player. The power cord plugs into the wall with the other end attached to the DVD player. The video cable plugs into the TV. If you have an HD television, the video cable will have a male HDMI piece that plugs into the TV while the other end of the cable plugs into the DVD player. If you don't have an HDTV, then you will use an RCA cable which has three prongs: Yellow, White, and Red. These three colored male prongs plugs into the corresponding color coded holes in the TV. The other end goes into the DVD player. When you have everything plugged in correctly and the DVD player is on, all you have to do now is change the TV input. You will need the TV remote that came with your TV, or a universal remote that has been configured to work with your TV. Find a button on your remote that reads "Source" or "Input". This will cycle through the sources and inputs of your TV including AUX, VIDEO1, VIDEO2, etc. Keep going until you are on the correct input to see the DVD player menu. Good luck!
Jul 01, 2011 | Philips 42PFL5332D 42 in. LCD Television
My dvd player is hooked up to the samsung receiver. I am using two remotes, one is the cable box remote where I hit tv and power and then cable and power and then the red power button on the samsung remote...
What you have to do is select the proper item on the receiver since that is what you have the dvd player connected to. Pressing bd/dvd on the receiver is not necessarily the right thing to do. All receivers have an input or source or function button that will enable you to choose the correct area where your device is connected. The way you have this hooked up may not be right but first things first. You will need to have a movie playing in the DVD player so that you see the numbers advancing. Go to each input/source/function on the receiver until you hear the DVD. Ok great! Now getting the picture is a little more tricky so please follow along carefully.
The cables going from the DVD player to the receiver: The cables should be connected to where it says OUT on the DVD player or hdmi out from the DVD player to one of the receivers INputs. Once that proper connection has been confirmed make sure the receiver is connected to the television for both video and audio. You must have a video cable as well as audio cables between the television and the receiver or an hdmi cable. If it is not connected to the television in this way that is the problem right there. In fact you probably have a cable going from the television's audio OUT going INto the receiver. In order to see your DVD player you will also need to connect the receiver's video OUT to the television's video IN.
You will need the television's remote to be able to change the source/input/video/aux on the television. You might be able to change it with the cable box remote by pressing tv and then input/source/video.
ALTERNATELY: You can connect the DVD player's Video OUT directly into the television's INput. The DVD player's Audio OUT cables would be connected directly to the receiver's IN.
Either way you will have to choose the correct input on the receiver as well as on the television itself.
May 16, 2011 | Samsung HW-C700
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
Need an instruction manual for an AWA DP602 5.1 dvd player for connection to a fujitsu plasma screen. will i be able to get TV channels programmed into the DVD?
IF YOU HAVE CONNECTED THE DVD PLAYER VIA COMPOSITE, COMPONENT, OR HDMI CABLES YOU WILL NEED TO USE THE REMOTE FOR THE TV AND PRESS THE SOURCE OR INPUT BUTTON TO CYCLE THROUGH THE INPUTS UNTIL YOU FIND THE ONE THAT YOU CONNECTED THE DVD TO. IF YOUR REMOTE DOES NOT HAVE THESE BUTTONS YOU CAN GO INTO THE MENU SCREEN OF THE TV AND PERFORM THE SAME THING USING THE MENU CHOICES.
HOPE THIS HELPS YOU. IF MORE ASSISTANCE IS NEEDED POST A COMMENT TO THIS SOLUTION AND I WILL TRY AGAIN.
Sep 15, 2008 | Televison & Video
Setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Feb 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Zenith TV
have u tried using a universal remote and programming it for your tv? sometimes universal remotes can break a code that a common tv remote cant, hope this helps, just a suggestion!!!!
Dec 28, 2007 | Televison & Video
Having trouble setting up dvd/vcr
Rich
Dec 25, 2007 | Televison & Video
Toshiba SD-6000 Logo
18 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
