Question about SanDisk Sansa E280 MP3 Player
How do you delete corrupted music files from Sansa e280 mp3 player
  • SanDisk Master
  • 7,482 Answers
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
BE CAREFUL and do not delete files needed to operate your MP3 player.
This is a FREE answer, Please rate me
Posted on Oct 17, 2010
I cannot delete songs from my Sansa e280. I have tried using both USB settings - MSC and MTP. When I try using "My Computer" it says it is deleting the files but they are still on the...
They are probably corrupt files. You will never be able to delete these unless you format your device, which unfortunately will delete all of your songs.
To format: Connect it to you computer, go to my computer, right click on Sansa and click on format. Once the format process has started don't interupt it. You will have to re-load all of your songs back on to the player, but at least your corrupt files will be deleted.
Mar 13, 2011 | SanDisk Sansa E280 MP3 Player
How do i erase music from my sansa e280 8.0gb mp3 player
Please rate me
Aug 23, 2010 | SanDisk Sansa E280 MP3 Player
I need to recover deleted memory
Try re-installing the drivers or updating it online :)
Apr 27, 2009 | SanDisk Sansa E280 MP3 Player
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Feb 16, 2009 | SanDisk Sansa E280 MP3 Player
Added music, but can't listen
I experienced a similar problem caused by corrupt files saved on the internal memory of my e280.
(I could not delete/remove the files) I had to format the internal drive of the e280
and re-copy the files back on to the unit. Works great now. When formatting the device
use the command from windows. (ie right click on the internal memory icon and select format)
Note: Formatting will remove/delete all the files (eg music,photos..) from the e280 so make sure that
you have backups.
Cheers
Nov 30, 2008 | SanDisk Sansa E280 MP3 Player
Is there an easy way to delete all the music off of my mp3 player?
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 17, 2008 | SanDisk Sansa E280 MP3 Player
I can't delete my music!!! Please help.
I'm having the same problem and trying to work through it. The problem is that your memory in the music section is corrupt. You may need to reformat. If I figure it out, I'll leave a note for others.
Apparently, this is a problem with this player. Not sure why. I've had this problem in the past and was able to fix it by disconnecting the battery and then reconnecting. But this time it's gone. I had a "bad track" message before it stopped.
Apr 06, 2008 | SanDisk Sansa E280 MP3 Player
it says in the user manual that you have to hold down the power/menu button for about 15 seconds
Feb 19, 2008 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
71 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
