Question about Weiser Lock POWERBOLT ELEC DEADBOLT
My Powerbolt 1000 only works with the key in the deadbolt lock. I have a code entered that unlocks the deadbolt only with the key in the deadbolt. Your help is appreciated.
  • 963 Answers
Follow this link to find out how to remove the cover for your Powerbolt:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Posted on Nov 09, 2011
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Weiser Power deadbolt works backwards on keypad
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
Aug 18, 2012 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Just installed keyless entry lock. Lock button works fine, enter code and deadbolt only partially retracts. Worked fine the first time, will not completely unlock since. Key works to fully unlock. Tried...
Your lock is under one year warranty, with a lifetime warranty if the problem is mechanical or the finish.
Here is a link to the website warranty information, and from there you can contact them for technical and warranty assistance:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Good luck-and please provide feedback if this helps!
Oct 11, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
I forgot the code and I lost the key
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
Aug 03, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
I am looking for a manuals for a weiser lock powerbolt 1000 can i down lord
powerbolt 1000
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
The instructions for reprogramming the code can be found there. Good luck!!
Apr 07, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
Weiser powerbolt worked well for several months but now is not reliable anymore. Changing batteries did not help. It sounds like it is locking but sometimes fails to lock...we cannot trust it anymore
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Good lock or good unlock
Feb 05, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
When i try to lock or open with key pad it will make the sound like its closing but the bolt does not move. can only lock and open with key.
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Jan 30, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
How to reset kwikset pwerbolt 1000
6. Resetting the code: - please follow these instructions to reset the code on your Powerbolt 1000 unit:
  • Remove the inner cover plate from the lock.
  • Locate the small round program button near the left side of the circuit board (Red or Black).
  • To program, the latch should be extended out in the lock position, press the reset button once, then enter your 4-8 digit code on the exterior keypad, then immediately press the middle lock button on the exterior keypad. You will hear a beep. Re-enter the same 4-8 digit code to confirm, the latch should retract. This completes the programming. This signals that your code has been accepted.
  • To enter a second code, follow the same procedures as in step 3, but this time press the reset button twice then enter your code.
7. Replacing the batteries: - please follow these instructions to replace the batteries on your Powerbolt 1000 unit:
  • Remove inner cover plate located above the thumb turn on the inside of the door
  • Replace all 4 batteries with quality alkaline AA batteries. (Do not use rechargeable batteries.)
  • Ensure that the batteries are correctly oriented or unit will not function properly.
8. Changing the password code: - please follow these instructions:
  • Manually put the bolt in extended (lock) position. Press PROGRAM button once, enter new 4 - 8 digit code and then press LOCK.
  • Press PROGRAM button twice, enter the same new code and then press LOCK once.
  • Press PROGRAM button three times, enter the same new code and then press LOCK once.
    These stept will program only the new code you enter for your unit.
9. Why is my Powerbolt 1000 unit beeping? - To determine why your lock is beeping, please follow these steps:
  • Take out batteries and unplug powerstrip.
  • Let is sit for 1 minute then put the batteries back in and wait another minute.
  • If it does not beep, the keypad needs to be replaced (17733-1).
  • If the unit beeps, the powerboard needs to be replaced (A17734-4,3 Powerboard 1460 brass finish; A17734-4,26D Powerboard 1460 satin chrome finish; A17734-4,5 Powerboard 1460 antique brass finish; A17734-4,11P Powerboard 1460 bronze finish).
Nov 02, 2008 | Kwikset Powerbolt/Electronic Deadbolt-...
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
147 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
