Question about Refrigerators
Fridge no longer stays cold, sounds like the fan or compressor is running but no cold air is coming out, freezer also is not working
  • aabranch Oct 17, 2010
    The copper tube that comes from the compressor has a little bit of ice formation where it enters the back of the fridge. Also the fan cover that I took off has a lot of dust/dirt on the screen
  • 2,973 Answers
If the fan is not working then the fridge will not get cold as the air does not blow through it. If the compressor is running and there is no cold air coming out of it then the fan is not working. The relay of the fan must have gone. Needs replacing.
Posted on Oct 17, 2010
    President:
  • Refrigerators Master
  • 1,932 Answers
Check whether in evaporator coil there is ice formation.? and check the evaporator coil fan is running?
Thank you
Freezer stays cold but fridge has been warm. I turn the thermostat to off for a day and then everything is ok for a week. Sounds like the fan is frozen solid when fridge doesn't work( no sound) Th
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts: http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jan 11, 2013 | Refrigerators
I have a ge side by side fridge model number GSH22JFXL ww and the freezer is working great but the fridge is not cold at all.
If the freezer is working great and you don't have frost build up on your coils (this would be a defrost problem) and your fan is running in the freezer, then first check your control settings.
put both your freezer and refrigerator controls in the middle position. your refrigerator gets its cold air from the freezer. the freezer control is actually the thermostat control. this controls the compressor. the refrigerator control is basically an air damper that allows more or less air in from the freezer.
by placing both controls on 9, you may think that you are turning both controls wide open when you are actually making the compressor run longer yet the air damper is keeping that cold air mostly in the freezer.
allow 24 hours for stabilization
Jul 02, 2010 | Refrigerators
Freezer works fridg dosent stay cold
When plugging it back in, check to see if you can feel air circulation (from vents in the top-rear) on the refrigeration side.
Check again after the fridge starts to warm.
There is a fan which is supposed to distribute the cooled air from the freezer to the fridge; this may be failing after the fan has warmed from operation. The bearings in these is primitive and can get sticky impeding the fan's rotation. Replacement of that fan is not covered by the (longer) compressor warranty.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator and freezer no longer cold!
Try disconnecting the fridge for a few minutes and then listen for the compressor to come on not just the fans.
Jul 02, 2009 | Refrigerators
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
