Question about Hannspree Computers & Internet
On my inch screen i dont know what happen but all i get is about a 12x16 picture can you tell me how i can fix it back to my normal screen
2 Suggested Answers
romeshtripas
SOURCE: how do i get my screen back to normal
type ctrl+alt+arrow key
Posted on Aug 24, 2012
While we're trying to watch TV, our Panasonic PT-AX200U HD projector will sometimes start alternating from a green screen to a blue screen and then to snow, and finally back to a normal picture. It's
You are experiencing Power Fluxuation. The Power Supply seems to be going out or on the way out... How old is the TV? Is it still under warranty?
Apr 08, 2013 | Audio Players & Recorders
No picture just on line in the middle left to right
I know the line is horizontal but the problem is in the "Vertical" circuit of the set that deflects the picture from the middle of the screen to the top and bottom.
Only a few easy possible reasons for this.
1) set has developed bad solder connections in the vertical output circuit--it happens as a normal thing and most sets like this the picture will have opened and closed before going to just a line.
2) a part in the vertical output circuit is bad---most common is a IC chip for output. Not real hard to get at or replace and is inexpensive.
If it is as stated here a 27 inch set it may not be economical to fix and cheaper to just consider replacing it.
Let me know if you have questions.
SD TECH
May 02, 2010 | Sansui 27 inch TV
Color alignment
This sounds like a convergence problem. Would you describe the picture like a 3-D one? If you can solder, you should be able to fix this yourself. Let me know if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Mar 26, 2009 | Hitachi 57F500 57" Rear Projection...
TV screen shrinking from top to bottom.
My Dearest, j30;
It sounds like you have a problem in the 9 volt circuit which feeds the vertical output ciruit; CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
This is not a repair that a novice should try, but if you call a factory authorized service center and have them come out and give you an estimate; AND tell them what the problem is, you will look know what you are talking about!
Aug 11, 2008 | Mitsubishi VS-45607 45" Rear Projection...
My laptop screen has rotated and dont know how to put it back to normal
press the ctrl shift and arrow up, down, left, right keys with ctrl and shift pressed together and arrow keys randomly to fix this
Jul 29, 2008 | Computers & Internet
Blurry Line at Top of Screen
Unplugged the TV overnight and it seems to have gone back to normal.
Jun 25, 2008 | Panasonic PT-51G43 51 in. Rear Projection...
Sony laptop vgn a190
hello
You need to open the pc and then refix all the components inside. verify also the memory chips, remove it and clean and then fix it back. if your noise maybe the hard drive got error. please tell me whats going after you do the solution.
melnavz
Apr 02, 2008 | Computers & Internet
Philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Mar 27, 2008 | InFocus SC-MANGRY-106H MANUAL PULL DOWN
Picture problem
Please PM me privately and I'll tell you how to fix this set.
Dec 26, 2007 | Philips 27PT6441 27" TV
Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
Computers & Internet Logo
29 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
Gregg Errera
Gregg Errera
Level 1 Expert
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
