Question about York Furnace Draft Inducer Blower Fasco # A224
Had a no heat call the other day on a York GY9S080B12up11a. unit was off on code 3, pressure switch. differential switch is rated for -1.2. hooked up the manometer and was getting -1.2. still wouldn't close. went to York and picked up a new switch. the guy at York told me the furnace i was working on needed a pressure switch with a -1.0 differential. so they gave me the proper switch, i popped it in and nothing. put the old one back in, turned it horizontally and it worked(i'm guessing thanks to gravity) for about a day. tried a new switch with a -1.2 rating, nothing. I'm fresh out of ideas. i've checked the tube's, they're good. cleaned out all the drains, checked venting, clear as a far as i can see, good slope. checked the I.D motor, seems good. any ideas for what might be wrong would be great.
  • 760 Answers
Make sure there is water in the drain trap. If the drain is "WIDE OPEN" the fan can draw air from the trap and not from outside, and the pressure differential will not be enough. This happens as the trap dries out over the summer, then when you start the furnace, the condensate drain from the fan is dry.On some furnaces this trap is a square box,anyway fill that tubing till you see water running to drain.If you read your manual it should tell you to prime the trap. Position of the switch, shouldn't matter, as it is s diaphragm that the vacuum pulls on to engage the switch. You're probably close to the setting, and by just moving the switch, made it operate.
Posted on Oct 17, 2010
Code p1400 gmc enjoy 2007 what is the problem in this code
Definition of Diagnostic Trouble Code P1400 Audi: EGR Valve Circ Electrical Malfunction BMW: Heated Catalyst Battery Voltage or Current too Low during Heating (Bank 1) Chrysler: Manifold Differential Pressure Sensor Circuit Malfunction Dodge: Manifold Differential Pressure Sensor Circuit Malfunction Ford: Differential Pressure Feedback EGR Circuit Low Input Hyundai: EGR System Monitor Malfunction Infiniti: EGRC Solenoid/V Jaguar: Exhaust Gas Recirculation Valve Position Control Jeep: Manifold Differential Pressure Sensor Circuit Malfunction Lexus: Sub-TPS Malfunction Lincoln: Differential Pressure Feedback EGR Circuit Low Input Mazda: DPFE Sensor Circuit Low Input Mercedes: EGR Switchover Valve Malfunction (C230 Only) Mercury: Differential Pressure Feedback EGR Circuit Low Input Mitsubishi: Manifold Differential Pressure Sensor Circuit Malfunction Nissan: Differential Pressure Feedback EGR Circuit Low Input Subaru: Fuel Tank Pressure Control Solenoid Circuit Low Input Toyota: Sub-Throttle Position Sensor Malfunction Volkswagen: EGR Valve Circ Electrical Malfunction
Jun 20, 2015 | 2007 GMC Envoy Denali
Tip
Mack Fault Codes List
FAULT CODE IDENTIFICATION TABLE - VMACIII - 1998 & NEWER
1-1 Engine Oil Pressure Sensor
1-2 Barometric Pressure Sensor
1-3 Fuel Temperature Sensor
1-4 Ambient Air Temp Sensor
1-6 Starter Input
1-7 Engine Coolant Level
1-8 (ASET CEGR) Estimated % Fan Speed
1-10 Aux. Cooling Relay Output
2-1 Engine Coolant Temp Sensor
2-2 (ASET IEGR) Boost Air Pressure Sensor
2-2 (ASET CEGR) Boost Air Pressure
2-3 Intake Air Temp Sensor
2-4 Trans Oil Temp Sensor
2-5 Front Drive Axle Oil Temp Sensor
2-6 Rear Drive Axle Oil Temp Sensor
2-7 Engine Oil Temp Sensor
2-8 (ASET CEGR) Combustion Air Temperature
2-9 (ASET CEGR) Combustion Air Temp Sensor
3-1 Exhaust Temperature Sensor
3-2 Engine Speed Sensor
3-3 Redundant Engine Speed
3-4 Engine Position Sensor
3-5 Engine Brake Output #1
3-6 Engine Brake Output #2
3-8 Trans Splitter Position
3-10 (ASET CEGR) Engine Brake Output #3
4-1 Vehicle Speed Sensor (VSS)
4-2 Fan Clutch Output
4-3 Auxiliary Output #1
4-4 Auxiliary Output #2
4-5 (ASET IEGR) Wastegate Output
4-5 (ASET CEGR) VTG Position Sensor
4-6 Tachometer Output
4-7 Speedometer Output
4-8 Customer Defined Statement
4-9 (ASET CEGR) EGR Valve Mechanism
5-1 Throttle Position Sensor
5-2 Throttle Position Sensor Reference Voltage
5-3 Engine Shutdown Lamp/Alarm
5-5 Electronic Malfunction Lamp
5-6 Spare Relay #3
5-7 Engine Oil Level
5-8 (ASET CEGR) EGR Temperature
5-9 (ASET CEGR) EGR Mass Flow
6-1 Fuel Level
6-2 (ASET CEGR) Turbocharger Speed
6-3 J1708/J1587 Link
6-4 J1939 Link
6-5 All Communication Lost - Engine Shutdown
6-6 Fuel Control Module
6-7 Power Relay
6-8 J1939 Link
6-9 Other ECU Affecting Operation
7-1 Service Brake Switch
7-2 Parking Brake Switch
7-3 Speed Control SET Switch
7-4 Speed Control RESUME Switch
7-5 Battery / Alternator Voltage
7-6 Switched Voltage
7-7 Exhaust Temp Reference
7-9 VTG Actuator
8-1 Electronic Unit Pump #1
8-2 Electronic Unit Pump #2
8-3 Electronic Unit Pump #3
8-4 Electronic Unit Pump #4
8-5 Electronic Unit Pump #5
8-6 Electronic Unit Pump #6
8-9 Solenoid Boost Voltage
9-1 Transport Protocol
9-2 Power Reset Without Key Switch
9-3 (ASET CEGR) Aftercooler Outlet Temperature
9-5 (ASET CEGR) Compressor Discharge Temp
9-8 (ASET CEGR) Auxiliary Output Device #1
9-9 (ASET CEGR) Auxiliary Output Device #2
9-10 (ASET CEGR) Auxiliary Output Device #3
10-1 (ASET CEGR) Internal Sensor Voltage
10-2 (ASET CEGR) 5 Bolt Supply
10-3 (ASET CEGR) Sensor Supply Voltage #1
10-4 (ASET CEGR) Sensor Supply Voltage #2
10-5 (ASET CEGR) Fuel Filter Differential Pressure
10-6 (ASET CEGR) Fuel Delivery Pressure
10-7 (ASET CEGR) Odometer Save Area Failure
10-8 (ASET CEGR) GPS Position Data Not Received
10-9 (ASET CEGR) Watchdog Timer Reset
source
on Dec 20, 2016 | Cars & Trucks
York diamond 90
The problem could be clogged hoses or hose connections or a bad pressure switch. Remove one wire from pressure switch start furnace as soon as inducer fan starts reattach wire if furnace runs replace pressure switch.hope this helps
Dec 11, 2013 | Heating & Cooling
Error code 6 on york diamond 90 furnace
That relates to a pressure switch fault. Unless you own, and know how to properly use a manometer this could easily be mis diagnosed. You have a combustion blower inside the top cabinet, and coming off either the blower assembly, or the cold end header box it's attached to there will be a round plastic pressure switch. It will have 2-3 wires, and 1-2 plastic hoses coming off. Depending if it's a single, or two stage model it may have two pressure switches, one for low fire, and the other for high fire. The switch will have a rating in "WC on it. If there's one hose going to the pressure switch, remove it from the pressure switch and attach it to a manometer. If you read a bigger number the switch is bad, if it's lower look for blockages in the vent, and intake pipes. If there's two hoses off the pressure switch then the difference in pressure has to be greater than the rating on the switch. Good luck!
Apr 18, 2013 | Heating & Cooling
I have a 15 year old York 80 diamnond unit and i have four flashes which tells me to open up limit? how do i do that? thanks.
A limit switch opens when the heat exchanger gets too hot. To check the switch with a meter turn the power to the furnace off, then disconnect the wires from the switch and set a meter to resistance, if the switch is open the meter will indicate infinite resisitance. There are several reasons why a limit switch opens and some of those reasons are
1) dirty air filter
2) the gas pressure on the gas valve is set too high
3) a problem with the blower motor
Jan 03, 2011 | Heating & Cooling
I have a York P2MPD LP Gas Furnace. During the call for heat it will not light. After 3 times it shuts down. With an error code 1. Here is the rub. When I remove the cover of the furnace and turn on...
I would suspect the air pressure differential switch. It looks like a diaphragm with a piece of tubing running to it and a electric switch mounted on it. Before changing it though, check that the condensate drain trap has water in it. I know that sounds silly, but if there is no water in the trap (if it's desperate from AC trap, then it can dry out in summer) you can be pulling air through the trap, and not enough pressure differential to trip switch. Also be sure the intake is clean outside. If there is any kind of Screen on intake be sure it's open. You can test switch with tester to see if it is the problem. The switch should close after the draft inducer fan starts.
Oct 08, 2010 | York Furnace Draft Inducer Blower Fasco #...
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
York 92 % eff. furnace shuts down on # 3 error (pressure switch)
i have fixed almost every one of pc9 -----we have installed in our company,code three{flashes} at first new presure switches installed, same thing,york knows about this,induction motor bearings,could be bad.our local york dist, has boards,inducer, ***.motor, dual press.switch,free.as is known as the only way to fix.after all else is ruled out.one local competator called us if we wanted to join class action suit . good luck.furnaces work good at first, season or two then bam
Nov 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
Goodman GMS90904CXA Wont ignite, light blinks 3 times
I had the same problem, I had to remove the lower black rubber stopper right next to the exaust fan and hook up a drain to the unit, as soon as the water drained out the furnace fired right up.
Nov 19, 2008 | Heating & Cooling
York  Furnace Draft Inducer Blower Fasco # A224 Logo
316 people viewed this question
Top York Tools & Hardware - Others Experts
Paul Carew
Lawrence Oravetz
Are you a York Tool and Hardware - Other Expert? Answer questions, earn points and help others
