Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
On/off switch not working. How do I get the plastic cover off to look at it? I think it's probably a very simple fix if I could get to it. Have to unplug it to turn it off.
  • Anonymous Jun 11, 2008
    I have a similar problem, though it's the opposite. I cannot get it to turn on. Pushing the button starts the vacuum (and holding it down keeps it on), but once the button is released the vacuum quits.
  • oakandel Jun 21, 2008
    I'm having the same problem. On/off switch not working, and must unplug to shut it off. Can't seem to get the housing off to view the switch.
Hello, my Dyson is dead, i've replaced the on/off switch with no change. To get at the switch, firstly pull off the bag/syphon box and then remove the handle. Behind the handle you will find 2 torx screws and 3 clips, when you have removed the screws and the clips, the front part falls forward showing the switch.
Posted on Jun 25, 2008
Hoover Supreme wind tunnel upright model. I have a bad on-off switch. How do I replace it?
Take the two screw off the handle and then remove the upper handle devise. This will expose the real on/off switch which is on the top of the unit. There is a plastic actuator that rubs up against the switch when slide the plastic switch on the handle. What happens is the plastic wears out and does not make good contact with the real switch.
A simple solution is to wrap duct tape around the plastic actuator to make it thicker, which then makes more contact with the real switch. Put the cover back on with the two screws on the back. Slide the plastic on/off switch an it will turn on and off again!
Nov 15, 2010 | Hoover U6630-900 WindTunnel Bagless...
I unscrewed the 4 screws on the bottom of my gen 3 mistakenly trying to replace wheels. now it turns on sometimes when the on button is pushed and sometimes it doesn't. is there an easy fix?
Easy fix... wow... um.. maybe.
I think that you may have accidently disconnected the metal arm between the foot pedal and the actual switch. Its not a problem, but you will have to open the top of the kirby unit to see if it has been disconnected or not. we are trying to get to the area above the wheels but below the foot switch.
first, take the handle and the bag off the unit and lay them down.
next, take the plastic covering around the switch off, you will need a flat screwdriver to take that off. the pry spot is just above the switch where you can slide in the screwdriver.
next, lift up the light and remove your belt/brush attchment off the front of the unit.
remove the 2 screws at the top portion looking just above the shaft sticking out of the unit.
remove the 2 screws behind the foot switch
you should see what looks like a 7/L chrome metal bar going between the footswitch and an orange plastic piece inside the unit where the bag goes. it should be inside the orange plastic piece and inside the lower portion of the footswitch.
I think that when you dropped the wheels it may have come off of the footswitch. re-attach and you should be good to go.
Good luck.
Nov 06, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Beater bar not working on newer ball pet unit
HighnTools posted this solution some time ago. I think it can help you solve your issue.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
Aug 29, 2010 | Dyson DC15 All Floors - The Ball Bagless...
The 'on' button isn't working/sticking
The ratchet mechanism within the power switch has failed.
There is no "fix" for this other than to repalce the switch with a new one.
If you have good DIY skills and tools, and feel competent to work on electrical devices, then it is possible to do this yourself, however Dyson dont make it easy !
The plastic switch covers (the bit you actually press) are normally held in place by a hidden plastic tag that is released using a narrow, flat tool such as a very small screwdriver or flat file. If you look very carefully at the switch cover, you should be able to see a very small "slot" on one side in to which you place the flat tool and "feel" for the tag. Once the swicth cover is removed, you can then access the switch.
Replacement switches are normally available on eBay.
If all this sounds a bit daunting, take it to a repair shop, or call Dyson helpline.
Oct 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Motor wont turn on.I checked the switch and I think it is working.motor turns on if a put direct power to it.`but it smokes at the brushes. can you help?
This sounds like either the belt isn`t on right or the brush is not slotted in the vacuum right remove the plastic or metal cover from the bottom and check by inspecting the belts ability to easly turn the brush rod check with your hands DO NOT turn vacuum on while plate cover is off it could fly off and cause injury.
Sep 05, 2009 | Kirby G4 Bagged Upright Vacuum
PHILIPS MOBILO PLUS (vacuum)- How to remove motor cover?
I found a solution. At least on my Mobilo HR8572. There are two tabs on the top plastic parts that hold on to the bottom plastic part. These tabs are located above the wheels, if you look closely you will see thicker grey plastic. You have to put a big screwdriver under the top plastic part and move it outward. The tabs are 6mm thick so you have to bend it out considerably. It then pops open. Works a treat and all the motor and electrical components are easily accessible using a simple star driver
Apr 05, 2009 | Philips Vacuums
Dyson dc14 power button
I just had this same problem tonight. As I was looking on this sight to find a solution, my husband fixed it. First he removed the extended handle part, then he took the 2 screws out behind the power switch and removed the front cover (directly underneath the power button). He then removed the plastic power switch cover and took the power leads off the switch and removed the switch and tapped on it, then the little button stuck in place:) Sounds silly but it worked! Good luck!
Nov 17, 2008 | Dyson DC14 All floors Bagless Upright...
Burning up the big black belt that propells vacuum.
See if you can pick up a nylock nut for the pulley. As long as your nut is a standard thread and not a reverse thread fastener.
nylock nut-homgkn40kjilovpbxhhmhqzq-1-0.jpgThese nuts are self locking.
This product Devcon Plastic Welder is the best plastic repair material I've ever found. Cures in minutes,can be drilled and sanded in hours. Great stuff to fix the hole in the plastic cover.
Apr 20, 2017 | Hoover U6630-900 WindTunnel Bagless...
Bissell 6900 stopped working how do I open the thing?
Bissell 6900 Digipro ON OFF Power Switch failed. I found the wire connectors for the power switch were corroded. I fixed this by soldering the wires directly to the terminals leading to the motor. To access the circuit board and the on.off power switch I pryed off the cover for the on /off power switch and the cover for the cord retraction leaver. The covers are held on by two tabs that extend under the red cover on the top of the vacuum. Push the switch cover away from the red cover while prying the cover upwards, You may damage the two tabs on the switch cover, as I did, but afterwards, the cover went back in place and appears to work okay. WARNING: This is a home made repair of a 120 VAC circuit. If you are un qualifued to do this repair you face serious risk of a faulty solder and fire inside the vaccuum cleaner. 4fd9446.jpg78baa14.jpg
Jan 26, 2008 | Bissell 6900 DigiPro Bagged Canister...
Manual for genie vacuum
Take the top part off and look at it. there should be some screws around the circumference of the top holding the upper part. remove these screws and the motor/switch section should come off. You'll probably find more screws holding everything else together. the switch fits into an all plastic holder and is more than likely a slide switch.
Sep 01, 2007 | Genie Company GV150 Wet/Dry Vacuum
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
65 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
