Question about Stanley Garden
We have a SBN125K brad nailer and it shoots two times or so then will not shtto then we mess with it a little and it may shoot again . what is the problem
rowdy45176
  • 2176 Answers
SOURCE: porter cable fc350a frame nailer shoots just air
Could be a couple things, first are you using the right nails in the gun e.g. collation and degree. Second do the nails move freely in the magazine and how is the pusher spring on the nail does it have enough pressure. Then I would unplug from air remove all the nails andjust tap the nose on a piece of wood and does the driver drop? If so the piston Oring is worn and needs replaced, but if you do that I would recommend replacing all the rubber. Let me know and I would need the exact model number to come up with parts.
Posted on Jan 25, 2009
mrhappyface
  • 205 Answers
SOURCE: craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Posted on May 29, 2009
rowdy45176
  • 2176 Answers
SOURCE: My brad nailer will not shoot any nails. When I
it sounds like the piston/driver might be stuck or the firing valve is malfunctioning. there are 4 screws to remove the top cap and you can see if the driver is damaged. Also before removing check to make sure there is not a nail jammed in the nose assembly. This tool is good for breaking the pin on the piston.
Posted on Oct 16, 2009
rowdy45176
  • 2176 Answers
SOURCE: brand new brad nailer shoots 2 nails and then it
first make sure that you are using the right guage nails and if so I would return it to the place of purchase for replacement., the blowing of air could indicate a jammed nail in the track, look for that first and make sure the driver is retracting fully.
Posted on Dec 19, 2009
  • 8 Answers
SOURCE: my mastercraft electric brad nailer stapler wont
Look for a jam in the gun.Sounds like a brad is "hung up" in it, probably right at point where it feeds into the mouth of the firing point. Be sure you unplug it before you do this.
Posted on Jan 15, 2010
MY POWER SHOT WONT SHOOT THE BRADS A LOT OF TIMES, WILL SHOOT STAPLES EVERY TIME
These tools are designed primarily as staplers, with a gimmick of being able to shoot brads. If you need to do a lot of brad nailing, purchase a brad nailer -- air or electric -- to do the job. In the meantime, try placing one or two drops of thin machine oil (3-in-1 is a common brand) on the impact area of the tool. Sometimes the adhesive used to form brads and staples into strips builds up on the tool surfaces and keeps them from moving freely.
Dec 31, 2017 | Staples Tools & Hardware - Others
Our Brad nailer model SB-1842BN is well oiled but it will shoot the brads just a little into wood or not at all. Help!!
Can u adjust the drive depth on the tip of the gun? My nailers all have a knob to adjust the drive depth. Also, what pressure are you using? I typically shoot mine between 90 and 120 psi. Hope this helps.
Jul 17, 2011 | Stanley Air Tools & Compressors
Does the brad nailer only use 2" brads or cam smaller nails be used also
Most nail guns are labeled with the longest nail/brad they can shoot but are capable of shooting shorter nails/brads. There should be a data sticker on the gun, usually on the magazine rail, or at least in the manual that tells you what pressure to operate the gun at, what guage brads the gun can shoot and the size of brads from shortest to longest it can handle.
Oct 22, 2010 | Sears TNT 3 gal Air Compressor with 2 in...
My brad nailer shoots staples without any problem but it jams on the second brad after being freed up from the previous jam. How to I rectify this problem. It is a fairly new stapler/nailer and has done...
Shoots staples fine but brads jam or bend. Check that the part called "guide bar", #35 on the parts diagram isn't getting stuck in the channel of part #30.
The guide bar retracts into the channel when driving a staple and springs out of the channel to guide brads.
The guide bar can get stuck in the channel if it's bent or gummed up. (Bent is likely the result of driving a brad into an obstruction.)
Mar 26, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
My black and decker 18v brad nailer will not shoot brad
look to see that you are shooting the right sized nails in it. 16 and 18 gauge nails dont interchange and the can get hung up under the plunger if the try to shoot at all
Dec 15, 2009 | Tools & Hardware - Others
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
Jan 09, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Garden Logo
Top Stanley Garden Experts
Dennis Key
Dennis Key
Jim Goldsmith
Jim Goldsmith
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Stanley Garden Expert? Answer questions, earn points and help others
