Question about HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop
HP Business Inkjet 2800 out put tray
I raised the output tray to load paper and now I can't get it to go back down and I'm afraid I'll break it, HELP!
    Sergeant:
  • 458 Answers
Do you have the printer instructions? They usually have this information. You can download them from the HP web site and see if it helps you. Without the printer being in front of me, I can't tell you how to do it.
Posted on Jun 04, 2008
How do I remove paper tray
Instructions
Grasp the front of the output tray located beneath the control panel. Remove the output tray by lifting the front of the tray up and pulling the tray out. Set the output tray aside.
Read more: How to Load Paper into an HP Officejet All-in-One Printer ' eHow.com http://www.ehow.com/how_4489317_load-paper-hp-officejet-allinone.html#ixzz2NjlQ4lhl
Mar 16, 2013 | HP Officejet Pro L7580 All-In-One InkJet...
Not picking up paper from tray 2
Is the paper put back far enough in the tray, it won't pick it up if it's not.
Feb 22, 2011 | HP Business InkJet 2800 Printer
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
How to load paper
Your model has two trays on the front. The bottom one of these two is where you load the blank paper.
1. Raise the output tray to load paper into the main input tray.
2. Slide the paper-width guide to its outermost position.
3. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
• Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
• Make sure all the paper in the stack is the same size and type.
4. Insert the stack of paper into the main input tray with the short edge forward and the side to be printed down. Slide the stack of paper forward until it stops.
5. Slide the paper-width guide inward until it stops at the edge of the paper.
Do not overload the main input tray; make sure the stack of paper fits within the main input tray and is no higher than the top of the paper-width guide.
6. Lower the output tray.
7. Pull the output tray extender towards you, as far as it will go.
I hope this helps!
Dec 08, 2009 | HP Photosmart C5280 Printer
Please load plain paper on tray 1,press resume
hi,
Check the media type and size that is set in the printer menu and also check you have same kind and type of paper u have in respective Trays.
Go to contol panel > printers and faxes > right click on printer icon > printing prefrences > go to the Tab, Paper/quality, under source select Printer auto select, click on apply.. try printing.. It will work.
any clarifications.., mail me on punithgowda@gmail.com
Aug 26, 2008 | HP Business InkJet 2800 Printer
Photo tray output problem
I fixed it just now and easiest, following the step below:
1) Can you see the blue thing between the paper tray and the printing tray? That's the Output Tray! Just press it back in as much as u could
(but don't break it). Then you trying print (testing), they might have a paper jam but its normal. After the jam, they will tell to dismantle the jammed paper at the back.
2) Shut down (or restart) your printer (unplug the power switch or it won't work). Plug it in again and then just simply its done!
3) If it won't work, repeat the previous step again... Good Luck ;)
Jul 29, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Business Inkjet 2800 - A3 Problem
Separate the Tray 2, on tray2, u would c couple of while rollers.. check how do they roll and clean for any dust.. While rolling if u feel any friction or any of the rollers broken.., then u need to replace tray 2.
Jul 15, 2008 | HP Business InkJet 2800 Printer
HP Compaq dc5700 Microtower - Free Flat Panel until 113007 EW287AV-KIM PC Desktop Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
