Question about Lexmark Office Equipment & Supplies
My scanner will not scan from the scan button
  • 99 Answers
What type of scanner, and what kind of operating system are you using?
try re-installing it...first un-install it (disconnect it from your system, shut down and then re-boot)and also un-install any software that came with it, then re-install it, using the directions that came with it for installation.
let us know what happens then...
Posted on Jun 03, 2008
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
When I push the SCAN button I get a message that asks me to 'specify the program where the scanned image is transferred'
You need to set up the destinations in the Canon software. First launch the Canon Scan-Gear Toolbox. The Scan button on the scanner is the same as Scan-1 button by default but no software is linked to this button. Click on the Scan-1 button then choose Set. Then set your application that you will want to work on the scanned image. Select your application (Photoshop Elements, for example) - the exe file if using Windows. (You may need to browse the Program Files folder and then the individual application folder (C:\Program Files in recent versions).) Then click Open and then Apply to confirm this. You can also select the file type that you want the scans to be saved as in this settings window.
If you want to change the scan destinations, then click on Settings (on the far right). You will see the drop-down menus for each of the scanner buttons. Select the desired function for the scan button and click OK. (Scan-1, Scan-2 and Scan-3 can be linked to other software.)
I hope this helps.
Oct 10, 2011 | Canon CanoScan N670U Flatbed Scanner
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
How to scan using an imac
  • Connect a USB or FireWire scanner to the iMac using the scanner cord and the ports on the back of the iMac. Turn the scanner on.
  • Use the CD or DVD that came with the scanner to install any required software drivers. If the manufacturer's instructions indicate the scanner does not require additional drivers, you can skip this step.
  • Put the object you want to scan face-down on the bed of the scanner.
  • Scan the object by pressing the "Scan" button on the scanner. Image Capture will launch automatically and display a low-resolution preview scan.
  • Set up the scan using Image Capture. The settings available will vary depending on the scanner you are using. With most scanners, you can select a specific area of the object to scan, choose a scan profile based on the type of object you are scanning, adjust the color options and set the resolution.
  • Click the "Scan" or "Scan to Folder" button to scan the object. The image will save to the "Pictures" of your home directory if you press "Scan." The image will save to whatever folder you specify if you press "Scan to Folder."
  • Oct 25, 2010 | Computers & Internet
    When i press the scan button , nothing happens at all ,, please help i need to scan photos
    The scan button requires proper setting of the program on the computer that tracks the state of that button.
    Reinstall drivers (full installation).
    Why not open My Computer, find the icon of the scanner and scan using Microsoft scanner or camera wizard?
    You can also open MS Paint and scan using File / From scanner or camera.
    Aug 09, 2010 | Office Equipment & Supplies
    HP OJ 6500 with windows7..Scan button on scanner is not working.
    The reason that you are unable to scan through the printer is, you are missing HP full feature software and driver.
    Please download and install it from the below link
    DOWNLOAD
    Regards
    Rizwan
    Feb 13, 2010 | HP Officejet 6500 Wireless All-in-One...
    I WANT TO USE THE SCANNER BUT, I DON'T NOW HOW, It go to the printer all the time, could you please help me ? I have the EPSOM STYLUS BX300F PROFESSIONAL, PRINTER,SCANNER,FAX,PHOTOCOPIER.
    Basically, you can use the scanner in two ways. Please open the scanner cover and place the document or image you want to scan face down.
    1. Press the SCAN button (color button = color scanning, black button = monochrome scanning). then your scanner will scan the document or image in the scanner tray.
    2. Go to the scanner program installed in your computer when you installed the printer. Open it and then click the command button SCAN.
    Note: Make sure that you installed the Scanner software when you installed the printer. Without the software, your scanner will not work. Please reinstall the printer including the scanner software.
    Feb 06, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    Scanner showing error 04 and cant let me scan
    Disconnect the power supply from the back of the scanner base.
    Disconnect the USB Interface cable and the ADF Accessory cable from the back of the scanner.
    Press and hold the E-mail and Copy buttons at the same time. While pressing the E-mail and Copy buttons, reconnect the power supply to the scanner.
    Reconnect the power supply and turn on the scanner.
    Press the Scan Doc button. the carriage will start moving back and forth in the full scan bed length. To exit test, disconnect the power supply.
    now try to scan the document ..........
    Dec 14, 2009 | HP ScanJet 7650 Flatbed Scanner
    Will not Scan. Gets message..
    Is it installed in windows as a scanner? Dont use scan button on machine try using scanners or document imaging software that needs to be in place on your computer, ie Document imaging in office or scanners and camera in windows, one sends scan signal from the PC, can use the scan button on scanner only when configued to do such. Scanner has software as does the printer both can found at HP web
    Nov 07, 2009 | HP Photosmart 3210 Printer
    How 2 use the scanner on the all in one epson cx7300???
    just reinstall your scanner driver and application
    Mar 19, 2008 | Office Equipment & Supplies
    124 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
