Question about HP Officejet Pro L7780 Printer
My HP L7780 Printer will not power off by the on/off button. Has anyone else had this problem? If so, are there any solutions other than unplugging it? Thanks
    Genius:
  • HP Expert
  • 1,325 Answers
Could it be that it is on power saving mode ?
read the specs on this printer
http://h10010.www1.hp.com/wwpc/ca/en/sm/WF06b/18972-18972-238444-3328086-3328086-3601421-2511717.html
if this helped you, please leva epositive feedback for me
Posted on Oct 17, 2010
I installed hp officejet pro l7780 but failed to calibrate.
Partial reset the printer
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
May 26, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
I need to reset my hp L7780 to oringal settings.
Follow these steps
1.Unplug the power cord while the printer is ON
2. press and hold # and 6 button at the same time
3. while holding them plug in the power cord
4. when the printer turns on release the buttons
It will take 2-5 minutes and it will restore the printer to factory setting that means you will lose all the numbers if you have saved in it and IP address if it has any.
Apr 13, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Our HP Officejet Pro L7780 All-in-One have had a paperjam. I have removed all the paper, but the printer shows the whole time there's a paperjam again. The printer makes a sound when you turn on the...
Try unplugging the power cord of the printer from the back of it while it's turned on and then plug it back in.
If you still gave the message try pressing ok and see if you get rid of it.
Here are some work arounds for that issue:*Try removing and reinserting the cartridges and make sure they are properly fitted in. *Remove and reinsert the duplexer *Try cleaning the rollers infront of the printer and from the back of the printer. *As for the rollers try, moving them and turn them around with your fingers. *Turn the power off and then on
This is a hardware issue already so if all else fails for your printer. It's better to just call tech support. If the printer is in warranty they will be able to replace it. If it isn't they might let you in on a good deal.
Feb 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
My HP 7780 always says phone off hook. When I disconnect the phone line for awhile and reinstall it faxes once properly then the phone off hook message reappears.
I use a VOIP line and get the same error msg. Here's what I do- I dial the fax number with the line unplugged (hence no off-hook message), press "start Fax", and as soon as I hear the fax machine "Click" to pickup the line, I put the line in the machine. Works every time!
Oct 10, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
The printer screen freezes and i cant do nothing i have disconnected the power sometimes it work but freezes again
Please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
May 13, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
L7780 has died. I unplugged the ethernet and the whole thing died
return under warranty....sounds like power supply or main board died.
Jan 28, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP L7780 will not align and will not print in black. When I print out the self-testpage, it prints only in magenta. I have gone through 5 hours of BS with HP and nothing seems to work.
I just went through this problem. I called HP and they said to do a Semi-Reset, which is where you first make sure the plug is directly plugged into the wall outlet, not a power strip or battery backup, unplug the printer while it is powered on, wait 20-30 seconds,and while holding # and 6 plug the cord back into the printer, wait for a message or blank screen and then push the "On/Off" button. This has worked for me a few times now, although you have to go through some setup to get it back to where you like it.
Dec 20, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
"Turn Power Off then on Again" error
Try performing a reset on the device. Unplug the power cable, then hold # and 3 while powering it back up.
Aug 20, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro L7780 Printer Logo
56 people viewed this question
Seeker5211
Seeker5211
