Question about Palm Zire 71 Handheld
Have installed program but when I try to HotSync, I get message "connection between handheld comp. and desktop could not be established. Everything is plugged in. I also get ":The Instapp.exe application received an error and cannot be started |(740)" What does that mean?
2 Suggested Answers
e-Guru
  • 3917 Answers
SOURCE: I have attempted to load
Are you upgrading from a previous Palm that synched using a serial cable? Even if not, you may have inadvertently set it up for the wrong interface. On your desktop computer, Right-Click on the Hot Sync icon in the system tray (next to the time) and verify that there is a checkmark next to Local Serial on top of the popup menu.
Also, verify the HotSync app on your Palm. Local should be selected above the logo and cradle/cable should be selected below the logo.
Double check your cables make sure they're connected properly, including the power for your Palm. Make sure the Palm is seated properly in the cradle and the Green light is on solid.
Please check the links bellow and read the articles therein related to your problem:-
http://www.companionlink.com/support/em/em0022.html
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,kb=PalmSupportKB,t=ooccase,case=obj(30421)
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 29, 2010
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Garmin hotsync issue
Hey uninstall the program, download the newest one available and try again.
Sep 08, 2008 | Garmin iQue 3600 GPS Receiver
I am unable to HotSync and cannot load HotSync manager
Reinstall Hotsync manager and make sure selected port is correct. Use alternate method to sync like Infrared
May 29, 2009 | Sony CLIE PEG-TJ37 Handheld
Can't get device to hotsync
First thought is that the cable has become defective - they do go wrong.
Assuming the visor is fine other than when hotsyncing, I suggest you reinstall the Desktop manager and hotsync manager on your PC or Mac, HAVING BACKED UP ALL FILES of course.
Sometimes the managers get corrupted and cause problems. Try that first, then check cable and finally a hard reset, assuming you have hotsynced recently and so won't lose loads of information.
May 21, 2009 | Handspring Visor Deluxe Handheld
I reinstaled the Palm Desktop again it worked....
Sep 20, 2008 | Sony CLIE PEG-TJ37 Handheld
I do not have a HotSync icon on my desktop or task bar after a local technician cleaned my PC. Now, I can not hotsync my data between handheld and PC. The handheld PalmVIIx screen states; "The...
you need to install again the software/driver of your device... it seems that your technician done a system restore on the unit or he remove/deleted files which associated with the hotsync software.
let me know
Jun 27, 2008 | Apple iPhone 3G
Selected com port not available
Please un-install and re-install the software,, that should fix the problem,
Jun 09, 2008 | Palm Treo 755p Smartphone
Hotsync (on its own) Problem
i have fixed this issue.
you must open up the phone a little ... with a soft tooth brush and clean around the connectors ... you probably spilled something and some rust has made a connection across some of the bus lines near the bottom of the device.
also clean near the bottom on the circuit board almost immediately right next to where the battery is.
Feb 07, 2008 | Palm Treo 650 Handheld
Hotsync problem
With a USB 1.1 machine .. try this ...My work around - disconnect ALL USB devices from the computer, NO multiport hubs, make a direct USB connection to one of the available open ports, then reboot the computer. Upon gaining control, then try to hotsync. If I had any other items connected or ran any other programs prior to hotsync, I was not able to perform a successful hotsync. The qwerks of the T5 and the sync conduits. Hope this helps Bob
Aug 09, 2007 | Palm TX Handheld
Vx to Outlook 2002 failed - no connection Established
hi, on ur palm tap on home , u would see hotsync icon tap on that , on the hotsync page , u would see ur name on top or just welcome , make sure u see direct serial on the same page , tap on the top left corner where it says hotsync in words , in the drop down , tap on lan sync prefs , make sure local hotsync is darker in shade. on the pc make sure u see the hotsync manager at the bottom right corner , if not , click on start , click on all programs , choose palm desktop , inside that u would see hotsync manager , left double click on that , if it doesnt appear at the bottom right corner , try 4times , then if it still persists , restart the pc and try again. Once u see the hotsync manager at the bottom right corner , right click on that , left click on setup , left click on local , choose a different com port , reduce the speed to 9600 , click on ok restart ur pc and try hotsyncin , if it doesnt work try the previous step again and do not forget to restart ur pc , and then perform a hs , it will work .... Regards
Sep 11, 2005 | Palm Vx Handheld
Palm Zire 71 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
