Question about Dell E172FP 17" LCD Flat Panel Monitor
My E172FP went out and the monitor on/off light is blinking green.
  • 11,361 Answers
It had shorted out transistors in the inverter circuits, that will be the first palce to look.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Oct 17, 2010
Monitor green light is on but no image what's the problem?
Pretty good bet that your monitor power supply has bad caps. There are about 6-10 caps that age and "bulge". The fix is simple. Google it. Total cost to fix (if you know how to solder) is probably less than $2.00.
Jun 09, 2012 | Dell E172FP 17" LCD Flat Panel Monitor
I have a blank Dell E173FP monitor with the green blinking light. I have ordered and received the repair/replacement parts. Can someone please respond with detail instructions to fix the problem? Thank...
yumaparkie, You mean to tell me you haven't been to YOUTUBE to see all the video clips of Dell E172FP, E173FP lcd monitors being repaired?? Do that first, then come back here if you still need help.
12fixlouie
Jul 15, 2010 | Dell E173FP 17" LCD Monitor
The power button is not working it blinks a green light
Disconnect the display from the Computer and remove its power plug. While the display is turned off, press and hold the power button for 30 seconds. After two minutes connect the power cord and the display cord to the Computer and the power source and turn it ON.
If the power indicator on the display keeps blinking, then it's required to open it up to repair it.
Feb 26, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My Dell Monitor on/off switch blinks green all of the time.
You need to open the monitor and check to se eif any of the capacitors on the power board are bad. Common problem for LCD monitors. The bad caps usually vent at the top (they will look bad compaired to a good capacitor).
If they look bad then they will need to be replaced. I've seen this in Dell monitors, so there's a good chance this will fix the monitor.
Take it apart, get the values on the sides of the bad caps in the power supply pcb. Buy new caps, and de-solder the old ones and replace them with the new ones. Don't forget to trim the leads afterwords.
Jan 01, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell computer windows xp pro. samsung syncmaster 731b cannot install right. says comp. cannot support default monitor installed ,
I need help monitor went blank and when I try to turn it back on it only blinks at the power button. took it apart and everything looks ok.
Mar 26, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Blinking monitor power button and flashing image
I buy and sell these monitors (Dell E17FP) the problem is with the transisters (Q739, Q740, Q759, Q760) they short out and the monitor will just blink on and off. You have to desolder them and test them with a simple battery and light circuit. The reason they blow is because of the dirty solder joints by the transformers. If only on pair of backlights work the problem maybe transisters Q751, Q743. I home this answers your questions.
Apr 28, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
54 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
