Question about NAD Audio Players & Recorders
Nad 7400 power envelope rec.on off button not working at all.remote control also not able to turn off &on.push button feels like it has no resistance ,pushes in to easy.please help
Soulvisitor
  • 1113 Answers
SOURCE: Printing Envelopes
Must use Tray 1 bpass to feed labels, on word change media type to envelopes ie page size,paper type and on printer set tray1 paper type to envelopes
Posted on Dec 11, 2007
jerryg50
  • 1689 Answers
SOURCE: Kenwood kr-v9020
You should find out who does the service for your reciever in your area. This type of fault can get fairly involved. It will require trouble shooting and then ordering the necessary parts.
The fault can be the motor, or the electroncs in the servo drive amplifier for the motor.
Jerry G.
Posted on Jun 10, 2008
  • 3 Answers
SOURCE: wii controllers wont work
Hi, i have just fixed the same problem with my controllers. You must re-sync the controllers. In order to do this, turn on wii, open back of first controller where batteries are and press red sync button, then open small compartment on wii beside where game goes in and press the red button, the first blue light should light up on your controller, repeat for other controllers, making sure to do this process for each controller seperately. Hope this helps!
Posted on Jun 11, 2008
SOURCE: Onkyo TX-DS777 Problem
man I think i have the same problem....
i push the power button but immediatly the LED turns off. I cheked the fuse but thats not the problem. Please if you solve your problem let me know...
my e.mail adress soy_robertog01@hotmail.com
sorry if you dont undersatnd me in some parts..im not very good writting english haha sorry..
Posted on Jul 29, 2008
SOURCE: Yamaha DSP-A2070
Check the 'front mix' switch on the back, set it in off; main level on max.
Posted on Sep 10, 2008
Where can i get the living solutions jumbo universal remote code for the samsung syncmaster 1701 mp tv
You should use the search remote code feature:
  1. Hold the device button you want to program for 3 seconds & release.
  2. Push & release the power button & the red light will remain lit.
  3. Push the CHANNEL UP button over & over slowly until the device turns off.
  4. When device turns off press OK button.
Hopefully that works for you.
Jan 07, 2015 | Samsung Televison & Video
I have an HTR-2 NAD remote. All the buttons except for the ON button are working. is there anyway to fix this?
Remote controls have an operating code which entered right will cause all functions to work. However if you were given the wrong remote or it doesn't have the right code, certain buttons will not work.
Check that the appliance it operates is the right model for the remote. Some remotes will allow reprograming others are fixed. If you can reprogram it will be just a question of finding out which code the amp uses and entering that. You can search online for the codes for your model.
It's not uncommon for the wrong remote to be sent out when first sold. Some people don't know it's wrong as the remote works nearly all the functions, just not all.
Aug 02, 2014 | NAD Audio Players & Recorders
Red light goes on and off
Needs the button put back into place. Look under the cabinet to see if there is an access panel below the switch, would go for all external controls. There would be a chassis with all the controls mounted to it.
Pull the plug before doing any repairs.
Look to see what it would look like in it's normal position. Something has moved out of place that holds the switch to the panel. Very tedious if you have to remove the whole housing.
Mar 14, 2013 | Toshiba 36A43 36" TV
My NAD T743 will not switch on. I haven't used for a couple of months and it was working just fine before. Now I tried switching it on using both the power button on the amp itself and the remote, to no...
Hi, have you checked the power button in the back to see if it got pressed by accident? It's a round button located right under the speaker inputs in the back.
Apr 11, 2010 | NAD T743 Receiver
Need program instructions
I need the model receiver you have to do this.
Jul 25, 2009 | DISH Network IR Remote Control
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Nad s200
It is most probably a dirty speaker protection relay. gently tap the relay(the one that engages shortly after turning the amp on) when the fault is occurring and see audio returns. This should ascertain the problem. Replace it if it is a sealed type, or if it has a "lid" you can get off, burnish the contacts with a white business card, and give it a spray with contact cleaner/lubricant. Good luck and a "fixYa" rating would be great for my profile :)
Feb 06, 2008 | NAD C370 2-Channel Amplifier
Problem with our TV - Sharp VT-G14
Try pressing and HOLDING the button on the remote for a few seconds. This button is a sort of "kid-proof" lock, to prevent curious fingers from playing with the TV.
May 16, 2007 | Sharp VT-G14 14 in. TV/VCR Combo
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
