Question about Jandy Lite 2 Natural Gas Pilot Light Heater
Jandy lte 2 heater....just replaced the a second ignitor within six weeks...heater is working but there is no temperture/pump reading on screen....
    Top Expert:
  • Jandy Master
  • 4,292 Answers
Check safety circuit
Posted on Apr 25, 2016
  • 22 Answers
SOURCE: Jandy lite 2 LG pool heater
ignition control board failure
Posted on Feb 18, 2009
  • 22 Answers
SOURCE: Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
SOURCE: low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
Posted on May 30, 2009
  • 246 Answers
SOURCE: How to fox flo 6 problem on Jandy lite2 175n pool heater
possible was the wron one I assume was the same one clean the filter clean the basket check for clog impeller
Posted on Sep 02, 2009
  • 8404 Answers
SOURCE: Jandy Aqualink RS4 randomly turns on blower, pump, heater
Re program your assorted timer functions and make sure you set AM and PM or use a 24 hour clock. I think your model allows for a 24 hour clock setting but I am not certain.
I hope this helps you
a
Posted on Oct 09, 2009
Jandy lite 2 f4 code
bad fuses to ignitor or bad ignitor replace
Aug 03, 2013 | Jandy Laars Lite 2 Pool Heater 125,000 Btu...
Jandy lite 2 pilot won't start
check fuses that go to ignitor if ok ohm out ignitor when unplugged should be about 78 ohms if shorted or open replace if ok check safety circuit
Apr 20, 2013 | Jandy Laars Lite 2 Pool Heater 400000 BTU ...
Why is my Jandy Lite 2 Pool Heater Tripping the Circuit Breaker
shorted ignitor remove the ignitor leads and see if it still trips if it doesnt trip replace the ignitor
May 17, 2012 | Jandy Laars Lite2 - 125,000 BTU Propane...
I CAN´T START A JANDY
This is the code for ignition lock-out.
This lock out typically happens when one of three things happens. I will start with the most common problems.
1. The HSI (hot surface ignitor) has gone bad. (this is easy to fix once you have the part. Part number is : R0457500
2. Flame sensor (rectifier) has gone bad or curroded and flame is not being sensed. This is also an easy part to repair. Part number : R0458600
3. Gas valve has gotten sticky or gone bad (this is not likely) . If this is the case, I recommend a professional replace the gas valve.
Open the cabinet so you have a good view of the ignitor. turn the power off, wait 30 seconds, then power back on.
After about 45 seconds the heater will send power to the HSI and it should glow bright orange/red.
If this i snot happening, its probably a bad ignitor.
If the ignitor glows, and the flame ignites, but goes out immediately, this would indicate a bad flame sensor. If you need help locating these parts in the heater, refer to the original manual.
http://www.jandy-downloads.com/heaters_lxi_manual.pdf
All parts are available on-line.
Or you can e-mail me @ adamh@newconceptchem.com to see if i have them in stock.
Nov 16, 2010 | Jandy LXI 400 NATURAL GAS POOL HEATER -
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
43 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
