Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears garage door opener (GDO) model 139.53985D, only a couple of years old. 315MHz remote controls. Opener has stopped responding to the remote controls,unless a remote is held wihin 12 inches of the opener. Controller board and remotes have been replaced, same results. I've shut off all circuit break switches to my house, also no improvement. Problem has been looked at by two different GDO repair services; neither could figure out how to correct this problem. Assuming some interference, is there any way to change the 315MHZ frequency to a different frequency?
    President:
  • 3,197 Answers
There is no way to change that radio frequency it is set by the government. Sears service technicians have an instrument to help them locate the interference that causes this type problem.
Posted on Oct 18, 2010
Chamberlain GDO light turns on randomly at any time of day or night. (Whisper Drive with Motion-Detecting Control Panel 935CB.)
If you don't have any puppies or strange animals running around your garage I would disconnect the wall control for a couple days. If your problem stops I would suspect that control. If you have a heated garage I would also make sure there is nothing that could be moving from the air movement from the furnace.
Apr 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Gar. door opener won't respond
There isn't a fuse. You are going to need to remove the cover on the opener and find out where you are losing the power. Maybe a neighbor has a volt meter you could use. I would check the power cord and then the logic board. Makes no sense but I would check for burnt or missing traces on the printed circuit board especially around that small transformer.
Aug 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programing garage door openers
Press the button on the garage door opener (red, green, or yellow) until the led starts to blink and within 10 seconds or so, ( I think it's actually 30 seconds) press the GDO control button on the remote and the opener should capture the signal and respond to it from then on. Any remotes that were set to control the opener will be wiped and the new one will be in control. There are instructions that came with the opener that show how to do this from the remote or the key-less entry. If you are talking about an in-car device then your vehicle manual may be needed too, but the main thing is to set the GDO to be looking for the code from the car remote and when you press the in-car remote the garage door should respond. If you have programmed a remote or key-less entry then it is about the same procedure.
Jun 12, 2009 | 2008 Subaru B9 Tribeca
Craftsman new 315MHz Garage door remote programming with old openers
The radio frequency has been changed so the two are not compatible.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Red light/stuck GDO Sears 139.53600
is it locked. does door lift manually. are springs/cables ok?
Jan 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
704 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
