Question about Refrigerators
Ours wont stop beeping and its not freezing at all we've checked the doors but they dont seem to be the problem
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 ..
Posted on Oct 17, 2010
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
Freezes at bios screen
im not sure about this but i think you need to replace the bios cos even tho you can get in but i will freez again and again
good luck
Oct 22, 2012 | Computers & Internet
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
Our bottom freezer has frost on the top part of it above the slide-out baskets. Where the light /light switch is located, there is dripping water. This freezes the light switch and a thin layer of ice...
There must be warm air entering the freezer compartment, probably via the light switch or the door gasket, check the door gasket with a sliver paper and it should not pull out from under the gasket with ease, if it does than its been damaged or the door got tweaked. If the switch is the problem you could seal it with silicone or something to stop the air migration
Jun 27, 2011 | Refrigerators
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Whenever I open the door the beeper starts beeping and continues for 19 beeps regardless of whether I leave the door open or close it again. The beeps are at approx 1 second intervels
Whenever the fridge is open it gives 19 beeps actually.In your case even when it is closed it is giving 19 beeps.This is the problem with control board.The control receives the signal when closing the door and stops the sound.Check the wiring connection to and fro the control board to the door.Control board costs high.This is small problem you can just unplug the wiring connection to the door to the board instead of spending more.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Feb 01, 2011 | Refrigerators
Our toyota is beeping and will not open with either the manual key the remote
Have you had cold weather latly or is it below freezing there by chance? I read somewhere that toyota siennas doors freeze shut constantly and make it seem like the keys wont work.
Dec 22, 2010 | 2007 Toyota Sienna
Our 3 year old GE refridgerator door seems to slam shut. could you give me some ideas for me to check and our refridgerator seems to be freezing the food. It freezes the milk on top shelf and freezes our...
make sure the fridge feet are even at the front it would seem the feet are too high and the fridge is on a backward lean allowing gravity to slam the door as there a re no springs in the door it can only be this
merry christmas
Dec 21, 2010 | Refrigerators
Kenmore HE2 Dryer makes three beeps but wont start
What happens is that the door switch gets turned inside. I just took mine apart because of the same problems listed. The switch has a tab inside that has to make contact with the internal switch. I pulled mine apart and turned it so it made contact...put it back together and it works fine now. After doing all that it seems like you could turn the swith from the outside a quarter turn with a pair of pliers and accomplish the same thing.
Mar 22, 2008 | Kenmore Elite HE4 Electric Dryer
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
