Question about Car Audio & Video
How do you connect a cd player to the brakes?
    Filmmaker:
    Uploaded 5 video answers.
    Scholar:
  • 82 Answers
Some car stereos that have a monitor require the parking brake to be engaged to activate the monitor. I assume this is what you are refering to. They make a by pass switch for this. You can posibly find this on ebay. What is the make and model for the player in question?
Posted on Oct 17, 2010
Cd player powers off
sounds like you may have a bad power or ground connection or have it wired wrong.
Apr 22, 2010 | Pioneer DEH-P6800MP CD Player
What does pink/brake wire on dvd hook up to?! Ex: -LF- spkr or red power?! what?! I have a "Farenheit TID 580" car cd/dvd player. I have all the wires hooked up except the pink/brake. Is there a wire on my...
Hi all car dvd players have a emergency brake safety feature. The pink wire is to be spliced into your emergency brake wire, or there is a code you can purchase to bypass this feature.
Thank you for using fixya.com
Feb 09, 2010 | Eclipse (AVN7000) Car DVD Player
How do i bypass emergency brake wire on my clarion to play movies
connect the wire to a ground/negative point, please note this is a saftey feature.
Nov 15, 2009 | Clarion Car Audio & Video
Braking wire (pink)
Does it connect to the negative wire of your emergency brake? If so just hook up the pink wire to a ground.
Enjoy
May 29, 2008 | Jensen VM9510 Car DVD Player
Car Stereo will not turn on
Most headunits (cd players) have fuses of their own. If those are are not blown, connect a simple test light to ground and with the ignition on, test your constant (yellow wire) and accessory (red wire) for power. If all fuses are good and you still have no power you can connect your red and yellow wires (whichever shows no power on the test light) directly to your vehicles fuse panel.
Jan 08, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
I got a ?
Normally, the emergency/parking brake has to be activated/engaged for the video player to operate.
By bypassing, you are simulating this condition even if in reality, the emergency/parking brake is not activated/engaged.
Solution > ground the video player's brake sensor wire rather than connect it to its intended connection point.
In some brands/model/versions of the video player, this would be light green (Pioneer, Clarion, JVC), green (Kenwood),
In some other rands/model/versions of the video player, there would be a bypass switch underneath a sticker, others would need a special adapter, still others have bypass option/feature in the menu/setup and some would require a toggle switch that would connect the dvd brake wire from positive to ground.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information. A reminder pls, in some regions bypassing is not allowed.
Good luck and kind regards.
Jan 05, 2008 | Dual AM/FM/CD/DVD/WMA 2.5 MONITOR Car...
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Brake wire for Jensen VM9311ts
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Sep 21, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Parking Brake wire on Jensen VM9311TS
It may need to see a Positive....not a ground (the brake wire rests at ground and goes positive when the pedal is pressed). but to answer your question, the brake wire for your car is Light Green and is at the brake switch above the pedal.
Sep 19, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
