Question about Kenmore Elite 45986 Front Load Washer
FH error The machine has an FH error flashing and will not let me open the door the door remains locked after pushing and holding cancel. The cycle time is also flashing and the machine(HE3t) seems to be stuck in the pumping water mode. I have unplugged the machine for the whole night and still nothing has changed. Please help, what can I do?
  • 5,911 Answers
If you click on the following link, it explains the "FH" error in great detail and how to troubleshoot:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If you still cannot open the washer door, here's another link you can follow that explains how to gain access inside:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Please read through the information carefully and let me know if you need further assistance. I hope you find this information helpful.
Posted on Jun 06, 2008
My whirpool locked light keeps flashing and wont wash
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 18, 2011 | Washing Machines
Kenmore Elite HE3 Error FH I forgot to turn the water hoses on when I started a load. The FH error sounded at 33 minutes of a 45 minute cycle. I can't reset the machine now. It is stuck. It is unplugged....
according to kenmore, you should press the "pause/cancel" button twice and it should release it.  it may also have locked up the CCU, central control module and might need to be replaced.
Aug 02, 2010 | Kenmore Elite 45986 Front Load Washer
It's STUCK
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer. Please post back for any further assistance.
Daniel
Jul 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-26 flashing
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door
switch is open while the door is locked for more than
5 seconds.
Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing
the Service History Mode:
Execute this procedure with an empty drum. All
of the steps below must be done in sequence
in order to reach the Diagnostic Test. This
executes the automatic test but does not show
the error history.
Close the door.
Push POWER.
Select the CLEAN WASHER cycle.
Press EXTRA RINSE four times within
5 seconds.
Press EXTRA RINSE to advance to the
next step of the test procedure.
If the starting procedure fails, push
PAUSE/CANCEL, then repeat the starting
procedure.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Door locks and F9 fault codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
164 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
