Question about GE Dryers
No heat changed igniter and coils igniter does not glow
    President:
  • 3,074 Answers
Http://www.applianceaid.com/faq-dryer.html#gasheat
Posted on Oct 16, 2010
There is no heat on any of the cycles.
Check Igniter, Igniter Sensor (Senses Igniter is glowing) & gas valve Coils. Remove Front or rear access panel to observe/access these items. Set heated dry cycle & start dryer while observing Igniter, should start to glow bright orange for several seconds, sensor should send millivolt power to valve coils that will CLICK opening valve producing blue flame for heat. If Igniter doesn't glow within a minute, its bad, If it glows & nothing else happens it's either Sensor or Coils are bad, check the coils by using Ohm meter across plug ends of coils, if bad you will get no reading on meter, coil is open & no good, or take both Sensor & Coils to repair shop and have them tested. All 3 are accessable thru access panel opening.
Feb 14, 2011 | Dryers
The dryer has no heat when turned on.
Check your coils & igniter. Access door usually located in lower right front of dryer. Remove (pry up & out from bottom of panel, if no screws, exposing burner assembly. Set dryer for heated dry and start, you should see the igniter glow bright orange (give it at least a minute) followed by a CLICK sound,(again, a few seconds) this is the coils opening the gas valve, followed by a blue flame for heat. If no glow, replace igniter. If igniter glows bright and no click, replace the coils.
Feb 13, 2011 | Dryers
The igniter glows but it wont heat
The burner power circuit is good as indicated by the igniter glowing. The problem now lies in the gas valve solenoid coils failing to open the valves to allow gas to flow be ignited. The coils are located on top of the gas valves one with two terminals and the other with three. Replace both coils to make the dryer heat up again.
Aug 02, 2010 | Kenmore Dryers
I have a Maytag Epic Z. The dryer turns on but with no heat
There are several things that can cause this. 1 st the thermal fuse(white plastic piece with 2 wires attached to it, then the igniter, is it glowing orange when you start the dryer, then the flame sensor located on the side of the burner assembly and finally the gas coils located on the gas valve close to the burner assembly. If the igniter is glowing orange and then going out without ignition change the gas coils, Hope this helps,
Feb 04, 2010 | Maytag EPICz Electric Dryer
MY GE GAS DRYER WILL NOT HEAT UP
check an pop the lil plastic cover on the front of the dryer an then turn the dryer on an see if the igniter glows after 30 secnds if it glows........** you probably have bad coils****if it doesnt then check the thermal fuse for continuity if is not checking ok replace it , that is one of the most common causes,
steps
1 check igniter for glowing
2 check thermal fuse for continuity test
3 if they both check ok an still no heat change the coils
good luck!
May 26, 2009 | Frigidaire GSGQ642A Gas Dryer
Gas dryer does not heat GAS DRYER DOES NOT DRY CLOTHES WITH HEAT
check for igniter to be glowing, remove the plastic tab on the front panel an start the dryer
if it glows igniter is ok takes about 30 seconds to glow.if it glows is ok.
then check the thermal fuse for conitnuity an if it checks ok
then you have bad coils. replace the coils an ur done
My dryer is not heating up, what is the problem
If the igniter glows white hot then change the coil pack if it only glows yellow or orange then change the igniter (glo bar).
Dec 29, 2008 | Roper RGX4634KQ Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Gas dryer is not heating up
Could be a bad set of burner coils. Does the glow come on for a bit then goes out. And after a bit does same?
Probably bad coils. If you were able to change ignitor, you can do the coils. Unplug first! The coils are the 2 black cylinder shaped devices on burner. They are held on with a bracket that has 2 phillips screws. You can probably take them to your parts house and they can ohm them out for you. Make sure to write down their position before removing them.
Nov 06, 2007 | Hotpoint NVL333GY Gas Dryer
Dryers Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
