Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Mitsubishi 62725 picture occasionally has slight horizontal lines. sometimes darker than other times. comes and goes. L.E.D. indicates light bulb has exceeded hours. If bulb is shot I would have no picture at all right?
  • Mitsubishi Master
  • 17,130 Answers
This is quite possible that there are dry soldering joints in the main board, the power supply sections, possibility of some capacitors that have changed value or is dry soldered.
I would suggest that you must remove the main board and do a good soldering of all the points suspected.
Make sure that all the connectors are tight, remove and plug back all connectors, clean the board, remove and plug back the lamp.
make sure the cooling is good and the fault is not linked with heat generation, if so clean the vents and allow flow of air.
Request that the work be carried out with caution specially when dealing in power circuits.
try this link for good soldering tips...Good Soldering tips.
The advice/tip given is with the belief that you are competent. You must attempt to do it yourself only if you are technically/logically able, especially when dealing with delicate devices, damaging while trying to open, Probing electrical/electronic circuits with high voltage or delicate components. Since the advice given by me is with the inputs provided and not based on a visual inspection, there can be further reviews required in some cases.
Posted on Oct 17, 2010
Mitsubishi 62725 lines scrolling in picture
Try first a DVD etc connected to a rear audio and video input, that may rule some things in or out.
Set does have a soft reset but it is unlikely to help for this issue
Dec 23, 2012 | Televison & Video
Picture flickers on Sony HDTV
Hi,It seems your ballast(board that powers light bulb) is going weak.The ballast was used to provide a lower voltage because lamp didn't use as much as brand new one. A newer one takes more voltage and when ballast doesn't provide as much power it will flicker or produce a dimmer image.I found the one for your tv here: http://www.discount-merchant.com/1091041-KDS-60A3000-p/1091041.htm?Click=48173 Good luck and God bless you!
Jan 06, 2010 | Sony KDS-60A3000 60" HDTV
Mitsu vs-5042 Works then picture goes out. Thumping works sometim
If you occasionally have a picture then you stand a good chance of repairing this tv. There are bad grounds on the deflection board. Start with the board that has the flyback. I do not know the year of your tv. Sometimes the same model may have an option improvement than one couple of months earlier. The first suspected problem would be the vertical IC. In some cases this ic is located on the convergence board and in others the flyback board. It has seven pins and is the TDA version. Located on a large heatsink. Resolder this and any other grounds on both board. Some will tell you the P I P board is bad. This is a free standing board that can be removed and replaced. But please do the earlier option first.
Jun 28, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Lamp Issue with Mitsubishi WD-62725
Hi I am Vortash it sounds as if the actual fault is in your ballast circuit this is the circuit that fires up the arc on the lamp and sends the signal to the main board that the lamp is running , if this is faulty no signal is received by the board and the lamp light comes on when this happens there is usually still sound but not always as sometimes the problem affects the power supply also .. this is a job for a trained engineer as voltages at the ballast are sometimes in excess of 25000 volts at first arc that then settles to a lower voltage to run ... regards Vortash
May 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Rolling horizontal lines on 62" Mitsubishi
That problem is caused by failed Capacitors on the signal and FMT power boards. which is a very common problem for mitsubishi TVs. There are repair kits available for the V26 dlp which contain the capacitors and instructions on how to do the repair. Heres a link check under the repair kits category.
Mar 29, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Horiantal line near top of screen
Suspect the Light Engine part # 939P977020.
Mar 08, 2007 | Mitsubishi WD-62725 62" Rear Projection...
Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Jan 12, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
