Question about Brother Office Equipment & Supplies
I'm trying to scan a 4x6 picture but when I scan it, it only scans as a corner of a regular sized paper (the rest is all white). I want to scan the photo so it comes up as just the photo and no white. How do I do this?
    Problem Solver:
  • 12 Answers
Hello friend
Please check out this search page, to see if you can find the answer to your issue. This is all I can suggest at present, as I do not know the model of your Brother printer.
http://search.conduit.com/Results.aspx?q=Manual+for+Brother+Scanner+&meta=all&hl=en&gl=uk&SearchSourceOrigin=3&gil=en&SelfSearch=1&ctid=CT2138084&octid=CT2138084
Kind regards
Barbara
Posted on Oct 17, 2010
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
My HP 6280 will not print the full picture after it has been scanned. I put it in the right hand corner, chose the correct paper size and it still won't print correctly. Can you please help
Check corner marking for placing the document, place the document & scan through system, verify whether you got full scanned image? if not adjust the placement in correct position, once its OK, go for print there select correct image size(could be 100%) & paper size..I hope it will solve the issue..Best of luck
Sep 25, 2011 | HP Photosmart C6280 Printer
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Printing 4x6 photos on photo paper
Sorry but your question seems to be unclear.
Here are the solutions that I see:
- try fixing the orientation of your paper on the printer:
-- go to printer "properties" then select "paper" then set it to
landscape or portrait. You might just have to cut the extra
papers
- try changing the paper size on the printer "properties" if it has
no 4x6 then choose "custom size"
Jan 19, 2009 | Samsung CLP 300 Laser Printer
Scanning
Using your cursor pull it down from one corner.
Aug 06, 2008 | HP PSC 2355 All-In-One InkJet Printer
Scanner
plz help me to understand: waisting paper by scanning?????
There is no paper to waist!
The machine scans the whole glass! The settings for scanning can be set by the scan software. Do have a look there. It might be that the settings auto crop the size.
In case you run copy do change the paper size.
Jan 22, 2008 | Brother MFC 420CN All-In-One InkJet...
47 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
