Question about Whirlpool Refrigerators
Refrigerator model ET1CHMXKB03. I have water collecting at the bottom of the fridge. the icemaker isnt hooked up. It appears to drip from the freezer..
  • Whirlpool Master
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly. The water your seeing it water that forms due to ice melting during the automatic defrost cycle. Most likely the evaporator drain is clogged with ice. This can be caused by the very end of the drain located under the unit where it drains water into the catch basin being clogged with lint / goo / gunk. The remedy is to manually defrost the refrigerator FREEZER section. UNPLUG the unit. Remove the contents and place a fan blowing into the freezer section for at least 2 hours. This makes a water mess so you will have to tend to the mess. After 2 hours, check the drain at the bottom of the evaporator to make sure all of the ice is gone. If it is clear and there is no standing water..... pour about 2 cups of HOT water from the tap down the drain to make sure it is clear. If it is still clogged use a piece of solid copper wire with the end cut clean or just the copper end folded back (U-shape) on itself so that you and push it through the drain tube and not poke holes in it. Then check the drain again to make sure it flows freely.
If you can not clear the drain the very end may have to be manually cleaned. You do this by removing the finger board from the back of the unit and reaching in to pull off the dry / hardened matter on the end of the tube. If you do open the back make sure to vacuum everything clean including the condenser coils before re-installing the rear cover..
If you need more assistance feel free to respond here. I will help you.
Thanks for choosing FixYa,
Kelly
Posted on Oct 16, 2010
I'm having the same problem, however it didn't seem to start happening till I had the ice maker hooked up. The drain tube is definately the problem since its all ice at the moment. I've seen the water dripping into the inside of my fridge and making a huge mess and when it drips... it POURS! Its almost like the its overflow from the ice maker or something. I was hoping to find more posts about this problem so I could get a better idea what it is.
Posted on Jan 30, 2011
Water accumulating inside fridge bottom make GE Model #gta18pbnaww
That's normal especially if you tend to leave the door open alot. Moisture from the outside air condenses and drips to the bottom. Also, if the refrigerator is automatic self-defrosting it will melt ice collecting around the refrigerator and the resulting water will collect at the bottom. Check under the food drawers for a drain hole. If it is clogged, clean it out. If it doesn't exist, periodically sponge out the bottom under the drawers.
Jan 12, 2013 | Refrigerators
Kenmore refrigerator model 363.9711781 water appears daily
This water comes from a plugged up defrost drain tube. Do you see like a cup at the back of your refrigerator connecting using a plastic tube in a hole at the back of your refrigerator ? This cup collects dripping water from your freezer during a defrost cycle - you will notice a hole above it on the ceiling - what drips into this cup and drains out back the hole in your refrigerator wall and into a long drain tube extending down into the drip pan at the bottom of your refrigerator, usually sits ontop of the compressor or in newer systems next to the condenser fan and evaporates. If this drain tube is plugged up with debris water will backflow back into your fridge and drip against the wall and under your cripsers.
During a defrost cycle (when you hear the sizzling sounds and all motors are off, open the door and you should notice water dripping.
If you can manually remove the cup yourself you can pass a piece of pipe cleaner or long cable and dislodge whatever is blocking it or if you can't do that you will need to have it serviced, sometimes there is a seal around base of the plastic tube it's best you don't touch or break it. Makes ure the cup is firmly connected and inserted into the hole, you can try raising the fridge a bit, the front part so it is slightly inclined to back. If all fails, have it serviced, it is a very simply problem easy to repair and common too.
Aug 24, 2009 | Kenmore Refrigerators
Water collects and freezes in bottom of Kenmore freezer of side-by-side freezer/refrigerator
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks!
Jul 15, 2009 | Jenn-Air JCD2295HES Side by Side...
The refrigerator is dripping water at the bottom of the fridge. Everyday we walk by the fridge and see lots of water dripping from the fridge.
Hi, The defrost drain is plugged. Remove the rear panel inside the freezer section and locate the drain hole. Remove all the ice and flush the drain out with hot water to make sure it is open. Some models require an after market drain heater kit. If you will get me a model 3, I can look this up and let you know if you need the kit.
Vic
Jul 04, 2009 | Refrigerators
WHIRLPOOL MODEL NO. ET8CHMXKBO4: WATER COLLECTING ON THE BOTTOM OF THE FRIDGE AND LEAKING TO FLOOR AT FRONT DOOR; ICEMAKER NOT CONNECTED. NO WATER IN DRIP PAN. DEFROSTER LEAKING SOMEWHERE BETWEEN...
The likely problem is the drain leading from freezer to bottom of refrigerator is clogged or stopped up. I will send you to another link so you can see and get pictures and answers to help you solve this.
http://appliancejunk.com/forums/index.php?topic=22.0
http://servicepartstec.blogspot.com/
Let me know if this help, Sea Breeze
Apr 24, 2009 | Refrigerators
Icemaker Kenmore
You either have low water pressure to the fridge or fridge water valve is not completely closing causing water to constantly drip through fill tube, Do you have a side by side? if so does water come out steady through the door?
Nov 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
11 year old amana bottom freezer icemaker drips water when filling tray
Hello dunc444444
Welcome,
You said, Bottom freezer works fine, but upper refrigerator has no cold air
Is your freezer so full that it is packed to the top especially in the rear?
Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
The water overfilling in the ice maker is an ice maker problem only.
When we install an ice maker there is a short white plastic tube that we push through the rear
hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
rolled the fridge out to clean under it!
Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
Let me know how you do?
Huuum {
Let me know.
Huuum
Please remember to leave a rating.
Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Refrigerators Logo
369 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
