Question about John Deere Garden
No start from no ignition kawasaki 14 hp fc420v engine wiring schematics John Deere LX172 Lawn Tractor
2 Suggested Answers
SOURCE: John deere gx345 has no spark at plug what is the cause?
need new coil pack or have short in harness grounding engine from running. check fuel line to carburator. 1. take float bowel off bottom of carb. do not touch float or pin holding float. crank engine over until fuel comes out of carb. If fuel comes out, you don't have fuel problem. put float bowel back on carb. 2. check for spark. take spark plug out of mower. put wire back on plug and place the threads on head [or metal of engine to ground the plug]. crank engine over for a few seconds to see if plug gets spark . [always double check with another spark plug that is good]. [[ Remember!!! you have to have someone sitting on the lawnmower to start. unless you by-pass safety switch [only do this if you understand how the safety switch works. NOT EXPLAINED HERE!!!]] If spark is present, there is no grounding problem. when engine is cool. 3. CHECK COIL PACK. for continuity. When the coil pack gets hot it will stop any juice to the plug. A>Check temp sensor B> Check Safety switches grounding out. C> Check for cut wiring harnes. [loose wires rubbing against pulleys, wires cut by rodents]. Hope this helps.........................GAS
Posted on Aug 07, 2012
John Deer 175 hydro garden tractor, Kawasaki FC420V engine wont crank when key is turned. Stopped cranking yesterday. Previously on occasion had to turn key on and off a few times to crank.
bad starter or bad ignition switch. try putting it in gear and rock it back and forth, if it starts then you have a dead spot in the starter.
Jun 11, 2017 | kawasaki Garden
Wiring diagram for kawasaki engine FC420V-DSoo on my john deere lawn mower
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
Best Manuals
May 24, 2017 | John Deere Garden
How to remove the old lower hood on a john deere lx178
JOHN DEERE LX172 LX173 LX176 LX178 LX186 LX188 LAWN GARDEN TRACTOR Service...
Apr 29, 2017 | John Deere Garden
FC420V Kawasaki back fires thru carb on cold start,runs and starts fine after difficult startts
It sounds like your valves may need to be adjusted...
if they are too lose or worn they won't seat properly and when the engine fires it blows back through the intake valve.
pull the cover and see if the rockers are loose... it only takes one to give you a headache.
Mar 29, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Lack of Spark
If all of your tests are correct, the thing remaining is the ignition coil. A bit of a pain to get at and expensive too. Parts diagram here. Before you buy a new coil, see if there might be just a broken spark wire or loose connection at the spark plug contact end.
Jul 16, 2010 | John Deere Garden
BACKFIRES THROUGH CARB,WONT START ,MOTOR IS KAWASAKI FC420V IN A JOHN DEERE LAWN TRACTOR
Most likely water in the fuel. Drain the tank and clean the carb. replace with fresh gas. Mr fix it is a dumby
Apr 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
136 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
