Question about Yamaha HTR-5940 Receiver
Yamaha htr-5940 with Acoustic Research wireless speakers AW877
I purchased this set of wireless speakers to use as surround (back)speakers for my system. The tranmitter has either a red and white RCA jacks or a headphone plug . The problem is where to plug them. If I plug into headphone the sound is great but I loose the front set up. If iplug them into the rec output and select tuner everithing works, when I switch the receiver to TV or DVD or XM (I have a Samsung HD and a Panasonic DVD) I loose the AR speakers but the front setup works fine. Tech supp. for AR is useless. I would hate to get ready of the wireless setup since running wires to the back of the room is virtually impossible. Any suggestions as what to do or add to the setup would be highly appreciated. best regards. Gian.
Use a 4 way splitter directly off the cable box 1 pair off cable to two out puts from cable box my setup works even tv is off I use it for music with tv off
Posted on Mar 01, 2009
Aw872 transmitter
sewing machines have speakers now?
Aug 29, 2012 | Sewing Machines
I was told i might have a fuse blown on my htr-5940,cause the 3 left speakers work for the test but not for actual playing.is that the problem?and where can i find the fuse?
There's no separate fuse for test versus operational speaker function.
Evaluate the source for why the "3 left" speakers (whatever that means) don't work for program material.
Jun 27, 2011 | Yamaha HTR-5940 Receiver
I have a yamaha htr-5940 and have hooked my PS3 directly to my Television with a HDMI cable and to the receiver with an optical cable, I am not getting any sound from my speakers (surround sound) am I...
get into the menu of the receiver and find "input settings" look for "audio" and set it to "auto" If it still has no audio, put it on the input it needs to be "DTV" "Aux" etc. then press input mode on the remote. It should say "auto" or "digital" if so, pull the optical off the back of the receiver and make sure you see a red glow. That let's you know a signal is present. If it's not, get into the menu of the PS3 and find the audio section and set it to Dolby Digital. If you still have an issue, post a comment and I will help you further. Hope this helps
Nov 07, 2009 | Yamaha HTR-5940 Receiver
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
Can Acoustic Research wirless speakers be used for surround?
yeah, I looked it up on thier website. Here is what they say.
Warning: This product is designed to work with line level outputs or headphone outputs only.
DO NOT connect it directly to speaker outputs as it will permanently damage the transmitter.
You can use these as surround speakers if you like. You just need a line level surround output on the receiver. Most high end receivers have this feature but, you may only have speaker level outputs.
If that is your case the only option you have is to use a "speaker to line level adapter".... http://www.crutchfield.com/p_543ADP12/Russound-ADP-1-2-Speaker-level-to-Line-level-Adapter.html?tp=9070
Now crutchfield.com is always a little high on prices but if you look around I have seen them around $10 online.
Good luck with your project.
Jan 28, 2009 | Acoustic Research 900MHz Wireless Stereo...
Left from speaker not working- Yamaha HTR-5940-6.1 channel
Redbird,
What do you have in the "multi channel input" jacks on the rear of the receiver? Those inputs Right, Left, Center, Surround R+L, and Sub are used when selecting 6 channel mode. They bypass the receivers surround processor board.
John W
Jan 10, 2009 | Yamaha HTR-5940 Receiver
HTR-5940 6.1 Channels
Every time this has happened to me it was either due to incorrect speaker impedance or incorrect polarity (+/- wires reversed).
Apr 21, 2008 | Yamaha HTR-5940 Receiver
Yamaha HTR-5940 won't stay on after thunderstorm
I have the same problem as you but no thunderstorm. Mine happened after I connected speakers with the unit operating and had a speaker wire short at the back of the unit. Got a whiff of smoke and now I have that DSL1U unit clicking same as you. Did anyone suggest a fix?
Feb 21, 2008 | Yamaha HTR-5940 Receiver
Sound cutting out
I'm presuming you are referring to a Yamaha HTR,right???(Night Listening Enhancer (Cinema/Music) and SILENT CINEMA)..see page 32 in this manual at this link,here's the owner's Manual,also available to download for free in .pdf (Adobe) format.......https://www.manualslib.com/manual/197349/Yamaha-Htr-5940-Av.html
May 09, 2017 | Yamaha HTR-5850 Receiver
Yamaha HTR-5940 Receiver Logo
179 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
