Question about John Deere Gator And Riding Mower Seat Cover
No start from no ignition kawasaki 14 hp fc420v engine wiring schematics
3 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: engine will not run at steady speed, govenor
On top of carb you will see a jet that is slotted,remove with screw driver and use a very thin wire to clean out hole in jet.Some had a black metal clamp holding it in place,remove that one by removing phillips screw,black clamp then use small pliers to pull jet out of top side of carb.If this does not work remove carb bowl and jetting in bottom-center of carb and clean jetting holes with a small copper wire.The mixture screw is for low speed air/fuel mix,this engine does not have a high speed fuel screw.Fixed jet.
Posted on Dec 11, 2009
  • 6468 Answers
SOURCE: i have no spark on my john deere hydro 175. fc420v kawasaki engine. replaced ignition trigger. whats next? thanks in advance for any help.
unplug the engine harness and then check for spark if you have spark its a bad safety switch
Posted on May 20, 2012
John Deer 175 hydro garden tractor, Kawasaki FC420V engine wont crank when key is turned. Stopped cranking yesterday. Previously on occasion had to turn key on and off a few times to crank.
bad starter or bad ignition switch. try putting it in gear and rock it back and forth, if it starts then you have a dead spot in the starter.
Jun 11, 2017 | kawasaki Garden
John Deer 175 hyudro tractor with Kawasaki FC420V-DS00 engine. Starter stopped turning engine over yesterday.
you can tell by bypassing the solenoid with a jumper wire, just touch it from one terminal to the other and if starter jumps you know it is good but only jump for a second do not connect only touch.
Jun 11, 2017 | Cars & Trucks
Wiring diagram for kawasaki engine FC420V-DSoo on my john deere lawn mower
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
Best Manuals
May 24, 2017 | John Deere Garden
I need gap setting for 14.0 HP Kawasaki FC420v
Spark Plug Gap Specs show .028 to .031
I set mine at .030 Hope this will help
Oct 21, 2016 | kawasaki Garden
Trying to wire to a external ignition switch
DIY starter remote mount solenoid easy step by step how to ...
? 7:45
www.youtube.com/watch?v=SgValPjmogw
Jan 25, 2013 - Uploaded by klowny1969 How To Wire A Ford Solenoid Step By Step Wiring Schematic . .... and just run the ignition switch wire strait ...
Oct 01, 2015 | Kohler PA-CH440-3031 Gas Engine, 4 Cycle,...
How can a kawasaki fc420v electric start be converted over to a pull start?
Basically, it cannot be converted to pull start without a lot of "engineering", but it is easy to bypass the starter switch as long as the starter itself is still OK.
Sep 04, 2014 | Motorcycles
FC420V Kawasaki back fires thru carb on cold start,runs and starts fine after difficult startts
It sounds like your valves may need to be adjusted...
if they are too lose or worn they won't seat properly and when the engine fires it blows back through the intake valve.
pull the cover and see if the rockers are loose... it only takes one to give you a headache.
Mar 29, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Need wiring diagram for Kawasaki FC420V engine
Send me your email and I'll send you a copy if this dosn't work...
This can be blown up too.
Apr 02, 2009 | Garden
John Deere Gator And Riding Mower Seat Cover Logo
372 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
