Question about Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Problem when try to turn on tv the red light just blinking and not becomes green as usual tried unplugging thr e tv for an hour and still same
    Problem Solver:
  • 6 Answers
OK. Here seems to be a solution that is working now. Unplug both the AVC and the panel (I used a power strip to make this easier by just turning off the strip and back on again). With the AC removed, press the "MAIN POWER" on. Next, press and hold the "VOL (--)" and "INPUT" at the same time. Finally, plug the AC power back in and the set should come on.
After it came on, mine was in a factory test mode. I had to enable the write mode (I think it writes to the PROM) and then selected the second line down on the first menu (1 of 15 ) to have it do the restore or something.
Finally, my set came up with OPC enabled to auto and it seems to have a sensor issue. At night, the monitor is unwatchable with such low light. So, I turned on a bright light near the monitor and set that to "Manual". so far, for two days and nights now it has been working again. I hope this helps. Good luck! -Brad
Posted on Aug 15, 2008
  • 53 Answers
Too Vague, can you be more discriptive.
Are you hooked to cable? does this happen when using Gaming? DVD, VCR?
Cable box?
Posted on Jun 03, 2008
2 Suggested Answers
SOURCE: red light on display not green as usual
I also has this problem, found any solution ??
Posted on May 27, 2008
I have a sony kdf 50e-2000 the green light goes on then it goes to thr red blinking lamp light. I have no sound or picture. If I replace the lamp light will I get sound and a picture again?
Yes, if you have not replaced the lamp since you purchased this TV.
Lamps usually last about 6000 hours.
I've seen lamps last much longer than 6000Hrs, it all depends on the usage.
Remove the lamp from the TV and do a visual inspection, see if there's a crack on the glass or the bulb.
If the TV is few years old then the Lamp may be bad.
For a new Lamp: 800 638-3328
https://www.encompassparts.com/
DO NOT BUY the lamp from ebay
Good luck to you.
Nour Sabre
www.tvservice.com
May 24, 2012 | Sony KDF-50E2000 50" HDTV
AKAI 27" Wide-Screen LCD TV,
The tv is in protect mode, try first unplugging power cord for one hour, and see if this solve the problem.
Oct 08, 2008 | Televison & Video
Green light blinking, tv won't turn on
Lamp lifetime is not 100% predictable. A lamp may fail without notice, although this is not usually the case. The picture is more likely to become noticeably dimmer as the lamp nears the end of its lifetime.
While there is nothing wrong with using a lamp until it fails, some customers may want to purchase a new lamp and replace the existing one when they notice that it is aging.
If the lamp fails in a Mitsubishi MicroDisplay TV, there will be no picture on the screen and a red front panel LED indicator will illuminate.
Jan 17, 2008 | Mitsubishi WS-65813 65" Rear Projection...
Blinking green timer light on front nearpower button keeps blinking, tv will not turn on, unplugged for 24 hours and tried again, also hit system reset and still nothing.
Thats a common problem when the caps on the DM need replacement. They will function fine untill power is interupted then the set will not complete the boot sequence when power is reapplied and the led will just continue to blink. Hers a link to the kit that will usually repair that issue the kit comes with instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
May 09, 2009 | Televison & Video
Sharp aquos red flashing light tv won't get picture
if the tv is still under the manufactuer warranty i would definitly give them a call. If it is a Sharp tv I would call the 1-87-BESHARP. I would also try unplugging the tv for at least 2-3 minutes and seeing if the tv will reset itself. Usually what happens with these tv's when the light blinks it locks the tv as a security issue. If the unplug does not help it will more than likely need service to get this fixed for you. The call line hours are M-F 7am-7pm S-S 9-5 and they will be glad to help you from there.
Nov 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Red light on display not green as usual
Apr 26, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Red light blinks
Check the lamp door (with green on) ,.. both green and red blink - bad lamp. Green off, red blinks..Try unpluging for 2 minutes and retry - if no different (sorry, call a service person).
Apr 21, 2008 | Toshiba 43H70 43" Rear Projection...
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
Tv wont turn on
stephster, check to see if you have a reset button on the back of tv good luck-hope this works for you
Nov 05, 2007 | Panasonic CT-36HL43 36" TV
Sharp Aquos LC-37HV4U 37 in.  LCD HDTV Logo
262 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
