Question about Samsung CLP-510 Laser Printer
Clp-510 constantly gives paper jam error, although none exists.
  • 3 Answers
False error message / could be due to the dirty rollers or bac=d sensors on the printer. Sometime when printer does not get enough power it might give this erropr message .
Hence also try to change the power source.
Posted on Oct 16, 2010
Testimonial: "BINGO! I had swapped power cords at some point. This smaller gauge cord was the culprit. I put a bigger gauge cord on and now prints like a champ. "
  • Just James Sep 12, 2011
    I have the same issue. I don't think it's power. I tried 6 different cords and different outlets. Anyway that doesn't make a lot of sense to me. Printers don't draw that much current and if they did, the problem would be the circuit breaker or melting insulation. There should be virtually no resistance in a power cord for a normal appliance unless it's badly damaged.
    Maybe it is a sensor glitch. I took out the rollers and cleaned them. I'm going to try compressed air and see if I can blow out any dust or debris, otherwise I may have to try finding professional help. I'm afraid that might cost more than the printer.
    By the way, what does bac=d sensors mean? Bad with a typo?
Hello and Welcome
If you are facing this error their may be small bit paper jam in side
There are some "micro-sensors" that detect a paper jam. There will be tiny piece of paper, or a lump of dust, inside those sensors, thus "tripping" the sensor and saying you paper jam.
To solve it :
Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
If you become sure that now really there is no paper, dust or foreign objects then
Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If problem still exist then best option to contact Samsung Printers Service Provider, Your problem will be solved,
I hope this solution will be helpful for you
Anymore help, I am here to help
Thanks
Mar 26, 2011 | Samsung CLP-510 Laser Printer
Samsung clp 510 model, paper keeping jamming please advice
where does the paper jam. in the drum unit or fuser unit. be specific so i can solve your problem
Oct 01, 2010 | Samsung CLP-510 Laser Printer
Samsung laser printer clp-550
When I this error on any printer my first question is 'Has somebody pulled on some stuck paper and torn it?' If people are honest and say 'yes' then there may be tiny piece of paper covering a sensor. Pull out the toner(s), fusers and paper tray(s) and look closely for any scraps of paper. They may be jammed in the parts that you just removed. If you have another of the eact same model you could simply swap parts to check none of them are faulty. Lastly, it may be worth buying a can of air and blowing it through the printer in case there is paper dust covering any sensors. Failing these, get the printer servied.
Please rate me if any of this helped J
Dec 12, 2009 | Samsung CLP-550 Laser Printer
CLP-550 Jam Inside Printer
Unplug the printer.
Uninstall all of your printer software. Reinstall it as if it where a new printer. Under printers select your model as the default printer.
Print a test page.
Aug 28, 2009 | Samsung CLP-550 Laser Printer
Error message paper empty free service
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Aug 21, 2009 | Samsung CLP-510 Laser Printer
Jamming when Print heavy paper on Samsung 510
printer only handles up to 120gsm,any thicker will jam.
Jul 11, 2009 | Samsung CLP-510 Laser Printer
My Samsung CLP-510 printer shuts down frequently for paper jam. However, there is no paper jam. To fix, I turn off the power to the printer for 30 seconds and after turning the power back on the paper
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Apr 14, 2009 | Samsung CLP-510 Laser Printer
Paper jam in tray 1
Hi glenpcr,
I had the same problem and solved it.
At my printer it was a problem of the MP-tray (multi purpose tray).
There are two hinges which keep the open MP-tray in a horizontal position. One of this hinges was broken and I just received it.
Just try it.
regards,
Stephan
Feb 10, 2009 | Samsung CLP-510 Laser Printer
Paper jammed
how to unlarge a paper jam in the compaq A3000
May 27, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Laser Printer Logo
310 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
