Question about Whirlpool ADG332 Built-in Dishwasher
I have ADG 758 and today all lights started blinking so i can not restart the program. How can I reset in order to be ablle to start the program again?
4 Suggested Answers
  • 188 Answers
SOURCE: ''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Apr 01, 2009
repairman45
  • 130 Answers
SOURCE: Hi. I have a problem with my dishwasher ADG 6556.
If this model has the normal wash, and heated dry buttons there is a sequence of buttons to press to do the reset, which buttons do you have, reading from left, to right on the touch panel.
Posted on Dec 29, 2010
Squalidstuff
  • 27 Answers
SOURCE: Dear sir, after only 2
F3 error fault code
The heating cycle is not working. The error is indicated after several electronic checks are done over a 25 minute period. Therefore if the heater heats too slowly or the heater is open circuit or indeed the electronic control PCB is defective, each of these will indicate F3. The twist is, if the NTC is fluctuating in its reading it also can indicate F3 and not F1.
Posted on Feb 21, 2011
Whirlpool dishwasher ADG 957
Try opening the door and holding the start button for 5 seconds to perform a reset. Then try to restart it.
Feb 11, 2008 | Dishwashers
Anti theft light blinking,dash lights up,windows roll up and down but car wont start. How do I start it?
If the anti theft light is blinking and you say that everything else fine.. My first thought is that the key is not programmed to the vehicle. The key has a internal chip that must be programmed to vehicle in order to start. Now my other question is, Is the key your using for the vehicle the original key or have you just recently had a key made? Regardless, in order for the yur Tribute to start, the key. Or keys have to be program to vehicle by your neighbor dealership. Thats the reason for your anti theft light is blinking
Oct 09, 2014 | 2001 Mazda Tribute
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
Dec 29, 2010 | Whirlpool Dishwashers
We change out battery in 2005 Xtype jag after we install battery and car was running as we was program the radio all the light on dash starting blinking and the car died
Sounds like an issue with the car's immobiliser. In order to prevent theft by disconnecting the alarm system when the power is cut the immobiliser is programmed to interrupt the car restart when power resumed. You will need to reset the alarm code.
Jul 04, 2010 | 2000 Jaguar S-Type
Adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
May 24, 2010 | Dishwashers
The program light won't stop blinking
Same here. I'm dead in the water. This started happening a few weeks ago and with patience and luck and different combos of buttons I'd get it to stop and I was able to brew. Today it just stopped completely. The program light either blinks constantly or stays lit constantly, but I cannot brew coffee. I see lots of people online with this problem, but have yet to see a solution.
Dec 08, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Whirlpool dishwasher ADG 7550. Starts cycle, water fills in then drains and starts beeping. Can be reset by pressing and holding the start button but problem returns on the restart. Any help on this...
high i have the adg7550 and the beeping again and again is the water sensor inside the left hand side.apparentley taking the plug off and cleaning contacts solves the problem this did work for me twice but now its being a pig.hope this helps.
Oct 27, 2008 | Dishwashers
Whirlpool ADG332 Built-in Dishwasher Logo
195 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
