Back to:
Tags:
Ricoh Aficio CL2000N Laser Printer
Lines priniting on copies
posted by Thom P on Jun 03, 2008
i have a ricoh printer and just recently i staated getting thin lines printing on the right side of my copies
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 06, 2008
Not Rated (0)
Bubbabear64
Rank:Wiz Wiz
Rating: 84%, 1191 votes
This problem happens with the PCU unit. Depending on the the usage of the Printer Control Unit it can be covered under warranty. This is a typical problem with these printers. Contact Ricoh for a replacement.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on lines priniting on copies:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
There has a been problems with the PCU. If you contact Ricoh, they can provide you with a new one. If it is under warranty, they can do it at no charge.
Thank You!
Can you Help with these Printers problems?
Print is crisp and clear on right side (3/4) of paper, but...
no yellow toner prints on test page
All black print is dim even after toner has been replaced....
For some reason (the only thing I can think of is adding a...
sir, when i am giving the print command then plain paper...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
