Question about Kenmore Kitchen Ranges
Surface works but clock wont come on to reset oven. it is brand new
  • Kenmore Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. Since you did not include a model number the only remedy I foresee at the moment without voiding your warranty is to schedule a warranty service call. You can contact them at this number: 1-800-424-2047 Your clock should be working and this is a valid warranty complaint. There are several things I could ask you to do but at this point all of them would be cause for voiding your warranty due to attempted repairs by un-qualified technicians. The clock should reset to 12:00 each time there is a power loss. You can try turning off the main circuit breaker for 10 minutes and then turning it back on after pushing it hard to off first. If the clock does not at least have a colon in it or... flashes 12:00 you have a valid warranty complaint. If all you see is a flashing colon.. push CLOCK then set the time and push CLOCK again. This should set your clock. To ensure your warranty stays valid do NOT attempt to do anything else. Make the call for warranty service using the number above.
Thanks for choosing FixYa,
Kelly
Posted on Oct 16, 2010
Multi purpose oven won't work after power cut have reset clock, light won't work. Is making all the right sounds just won work
power supply from clock damaged not by power cut but voltage spike when power resumed the oven thinks its in auto mode permanentley thats why it wont come on ,new clock or power board needed.
Feb 03, 2017 | Neff Ovens
Just bought brand new oven and the fan cones on but wont heat up. I have set the clock as the instructions say this has to be done before the bottom fan assisted oven will work.
Contact the store where you purchased it, it should be under warranty. They may be able to help you on the phone. They will know the brand etc.
Oct 31, 2015 | Ovens
How do i set up brand new oven , the fan comes on but no heat
If your oven is brand new, just check if it's properly connected.
You are not supposed to set up ovens, . Ovens are not as smartphones or computers. They are supposed to work when you install them.
So if it won't work, call warranty service
Hotpoint oven bs43
you need to send the full model number,most likely you have a bad clock assy.even though your clock might work it comes with the clock and a computer board all together.i never heard of resetting a timer,i do know that if you unplug or shut down the power from the fuse box for 5 to 10 minutes sometimes resets the computer just like a regular house computer, it sounds like your loosing power and i don't think resetting anything is gonna help you,also make sure you have 240 volts going to the oven,but if the fan and light are not working and no heat it sounds like you have a bad clock assy.if it's in good shape and depending on the age you might want to call someone in to check it for you,if it is the clock assy. it might not be avalable anymore but there are companies that can rebuild the clock assy. you have.good luck with your oven.
Jul 10, 2013 | Ovens
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
Jul 06, 2011 | New World Ovens
RECENTLY MOVED INTO A NEW HOUSE WITH A NEFF DOUBLE OVEN (OLD ONE). THE CLOCK IS FLASHING ALL THE TIME AND NOW THE MAIN OVEN WONT WORK - CAN YOU HELP PLS
Your oven might need to be reset first before it will work again normally.
The most common reset for NEFF double oven is to press and hold down the two arrow buttons while turning the small knob
Try it!
Oct 04, 2010 | Ovens
My clock wont reset and keeps flicking over to auto so it stops oven from working.do i need a new clock?
Yes, or you can have it by-passed, which will send your timer blank and the ovens will work.
Nov 01, 2009 | Rangemaster 110 (Gas) Kitchen Range
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Door wont shut and the light stays on
Since this is a new install, check around the perimeter of the oven door and see if it is closing all the way flat against the surface. The hinge could have partially popped out and needs to be reset. Can you tell if the oven door is popped out at the top portion of the oven door or the lower portion of the door?
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Whirlpool RBS245PDS Electric Single Oven
Surface units working, oven is not. clock panel is blank.
Sounds like your going to have to replace the control board. Sometimes after a power failure there's a surge when the electric comes on and this can fry a control board.
May 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
76 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
