Question about Garden
How do you put a chain saw chain back on and how do you determine the proper tension?
    Problem Solver:
  • 4 Answers
You obviously have taken the chain and bar off the saw. Start by meticulaously cleaning the oil port/s. At the front of the bar on the engine side, you should find a screw that moves the blade back and forth. Turn this screw counter-clockwise to allow placing chain loop on the bar and drive gear. Make sure that the sharp portion of the tooth of the chain is facing toward the engine of the saw, then the cogs will fit correctly. At the back end of the screw that you turned, is a nib that fits into the blade of the saw. Once you start assembling it,you can tighten the screw. Tighten the two bolts holding the blade and chain just enough so that you can still adjust the screw. Now, tighten that screw to a point where the chain can still be moved freely, but does not have a droop on the under side of the blade. Tighten,run the saw a bit, readjust if necassary and you are ready to go.
Posted on Oct 17, 2010
My chain came off and i can't get the bar back to put the chain back on, help
Hello mingster. Just inside of bar is a screw for adjusting the tension of the chain. The screw hole maybe full of dust & oil. Rotate the screw while holding the chain next to the tip of the bar to determine clockwise or counterclockwise. When adjusting the chain tension don't over tighten.
Sep 01, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain fell off and I can't get it back on.
Turn the saw off. Look for several nuts on the right side of the saw that hold the cover on and the blade to the saw. Loosen these nuts, and before taking the cover off, loosen the chain adjuster by turning it (usually a screw head on the same side, or on the front of the saw as you look down the blade towards the saw.) Loosening the chain adjuster moves a pin that goes into the bar (the part the chain rides around when operating) to push it away from the saw to tighten the chain when you are tightening it. Take the cover off, and put the chain around the sprocket at the back like a bicycle chain, and then while holding the bar (sometimes a partner helps) parallel to the saw and outward away from the front of the saw, align the bottom parts of the chain inside the bar guide slot all around the bar, holding just enough tension that it doesn't fall off the sprocket or get misaligned in the bar guide. Try moving the chain a little bit to make sure it is not binding on anything. If it doesn't move at all, make sure the chain brake is not on. Once it is moving smoothly, put the cover back on, and begin to hand tighten the nuts. Just before they begin to get tight, eyeball where the chain tensioner pin is in relation to the hole it is supposed to go in. Adjust the chain tensioner screw to move the pin towards the hole. When it pops in the hole, continue tightening the nuts by hand until tight. Now you and your partner can let go of the bar. Adjust the chain tensioner for the proper tension in the chain, not too loose, not to tight, refere to your manual. Finish tightening the cover nuts using the universal wrench to the specifications given in the owners manual.
Sep 06, 2011 | Poulan 14" Electric Chainsaw
How to change a chain
First of all, make sure the saw is off. Also, before removing bolts, make sure the chain brake is not engaged (the chain should move freely).
Remove the guide bar side panel. Using a scwrench or wrench, unscrew the nuts and remove the plate to access the chain.
The side plate on most chainsaws will be held on by two nuts. Loosen the blade adjustment screw (a pin that is usually driven by a screw and pushes the blade out from the chainsaw to keep the chain tension tight).
The old chain is ready to be removed now that the sprocket plate is off of the saw. Pull the nose of the chainsaw's bar away from the chainsaw to release it from the tensioner.
Remove the old chainsaw chain.
The chain will easily remove from the guide bar with all that slack in it. Note the orientation of the cutting edges of the chain so you put the new one on the same way.
Pull the drive links out of the guide bar and slip the other end of the chain around the clutch drum.
Steps to Install a New Chainsaw Chain
Thread the new chain onto the saw.
Carefully thread your new or recently sharpened chainsaw chain around the chainsaw's clutch drum, making sure that the drive links engage in the sprocket.
Thread the rest of the drive links into the guide bar and around its nose, making sure all links are in the guide bar slot.
Align the guide bar.
With the chain properly threaded along the clutch drum and guide bar, put some tension into it by pulling on the nose of the guide bar away from the chainsaw.
While pulling the guide bar, make sure to seat it onto the saw's adjustment pin.
Replace the side plate.
The side plate is ready to go back on as long as the guide bar is properly positioned beneath.
Replace the plate and the nuts that hold it into position, but do not tighten the nuts down all the way yet. The guide bar must be allowed to move a little while the chain is tightened to the correct tension.
Tighten the chain to the correct tension. Use the tensioning screw to the side of the guide bar to adjust the tension on the chainsaw chain.
Finish tightening the side plate nuts.
The chainsaw chain replacement is now complete.
And here is a great overall reference guide to keeping a chainsaw sharp and running. Sharpening a chainsaw chain is a great way to extend the life and is less expensive and easier than replacing a chain. There are small grinding tools (like a dremel) that can be run off a small 12v battery or your vehicle battery that allow for quick 'tune-ups' on your chain if you are out cutting and need to sharpen your chain.
http://www.pcta.org/pdf/STUCHAP2_web.pdf
Aug 28, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do you put the chain back on the track of a Husqvqrna e series 235 chain saw.
You need to make sure the blade is not damaged. You need to release the chain tension screw, most cases; you turn in counter clock wise to release the tension rod. Do it in the reverse when you reinstall chain to tighten it back up to operating conditions.
Aug 25, 2011 | Husqvarna 450 e-series 18" Chain Saw
My saw threw a blade . I took it apart to put the blade back on I have tried everythingbut the blade ,which is the proper one isI about 1-2 links too long. this is w/ the tensioner all the way out. Any...
I would say that it's time for a new chain. After using for varying periods of time the chain will stretch too far to be used anymore. This is caused by heating during usage. Some things that will cotribute to chain wear out are insufficient bar oil, dull chain or just every day wear. I think if you get anew chain you'll be fine. When I'm tensioning my chains I run the saw at high rpm for a couple of mins. Shut off and grasp chain by mid-point of bar and lift up. I try to get enough space to slip a nickle between bar and bottom of chain. You should check tension often, as over tightening also adds to wear on chain and motor. Hope this helps you. Thanks
Nov 14, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
I was using the saw as a chain saw last weekend to cut up an old tree stump when the chain came off. I don't know how to access it to put it back on and don't have a user manual. The saw belonged to my...
You will have to remove the cover on the side the chain bar goes into. There should be one or two nuts holding the cover on the side. The is also a chain tension adjuster you may have to loosen to put it back on. Make note of the direction of the teeth on the chain. It is an directional chain. The tension adjuster is usually a flat head screw on the front side right beside the chain bar.
Unless it is a really old saw, manuals are available from most manufacturers for free download. See if you can locate a brand name and model number.
Jun 16, 2010 | Remington Electric Pole Saw
How do you adjust chain tension? I have the 16" Remington electric chain saw, and the chain will not stay tight; it slips off the rear sprocket as soon as I try to use it. I don't feel everything is...
Here is a link to instructions for EL-8 series saws ... http://www.desatech.com/pdf/115499-01_EL8_Series_Chain_Saw_Tension_Adjustment.pdf. For series LNT-2, LNT-3,EL-1, and EL-7 according to the manufacturer... "WARNING: The cutting edges on the chain are sharp. Protective gloves should be used when touching the chain. Unplug the chain saw from the power supply. Allow chain to cool. Loosen the guide bar nuts until they are finger tight. Ensure the adjusting block is in the adjustment hole in the guide bar. Turn the chain tensioning screw clockwise to increase tension. Turn the chain tensioning screw counterclockwise to decrease tension. Check for proper chain adjustment by pulling down on the chain at the bottom center of the guide bar. You should see no more than a ⅛ inch gap between the chain cutting links and the guide bar. The guide (or drive) links should not come out of the guide bar grooves. The chain should rotate freely around the guide bar. If it does not, chain tension should be decreased. When the chain is properly adjusted, tighten the guide bar nuts securely." On the M series if your chain keeps slipping off your sprocket... The Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. I hope this helps you!
Jul 01, 2009 | Remington 16" Electric Chain Saw
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
My first chainsaw...am seeking general advice on product use etc
Ok to get correct tension on chain, basically loosen it a little until the chain on the underside of the bar is hanging a little... Now start tightening it up again. Basically you want the chain (the main part of each link) to be just touching the the underside of the bar. This will give correct tension... Note that chain does expand as it heats up so it may loose tension... so this is perhaps best done when the saw and chain has warmed a little. Also, new chain will stretch a little naturally so check tension each tme you use the saw.
If you do not know hoe to sharpen a chain properly, it is best to get someone else to sharpen it, or buy a new chain... Eventually all chains will need to be replaced because they can only be sharpened so many times before the cutting teeth become too small to work effectively or safely.
As for oil, if it is an electric chain saw, you only need chain/bar oil. Any good name branded bar/chain oil designed for chainsaws will work well.
Please rate my solution on FixYa!
Thanks.
Apr 01, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
