Question about Linksys Wireless-G Broadband Router
Adding a printer to wireless router
I am trying to add a printer to a linkssys wirelesss router. My router does not have a usb port, nor does my printer have a cat 5 port... Is there a cable out there that does this? what do I need to make this work?
    Top Expert:
  • Linksys Master
  • 11,573 Answers
Hook printer to wireless router
Posted on Jun 29, 2016
  • 65 Answers
You need a print server. It is a box that hooks to your printer and then the box communicates with your router. Here is a link for some on bestbuy.com
http://www.bestbuy.com/site/olspage.jsp?_dyncharset=ISO-8859-1&id=pcat17071&type=page&st=Print+server&sc=Global&cp=1&nrp=15&sp=&qp=&list=n&iht=y&usc=All+Categories&ks=960
Posted on Jun 03, 2008
Can i hook up my printer to my wireless router and if i can how do i tell it to print when i need it to print
The iP6310D can't connect to the wireless router directly. It has a USB port and an optional blue-tooth receiver.
If you connect the printer to one computer, you may be able to share it using that computer as a server. Install the printer software on all of the machines. For the software, see http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip6310d#DriversAndSoftware . For Windows 7 and 8, if you set up a Homegroup, enable sharing for the printer on the computer that it is directly connected to. Then use Add a Printer command from the Devices and Printers Control Panel option to locate networked printers. For other OS options, you'll need to make sure that the computers are in the same workgroup. (See the Network set-up information.) Then add a network printer.
If your wireless router has a USB port, you may be able to connect the printer to the router. Again install the printer software on each computer. Then use the router's software to add a printer on the computer. (For Linksys routers, that is the Cisco Connect software. Some routers may not offer this software for all OS's or for all printers.)
A similar option is a print server connected to the USB port of the printer. You will need to check the specifications for each one. There are some that only work on select printers.
Once the software (the printer driver and then the network software/shared printer is set up), then any program should be able to print following the File > Print command.
Please add a comment with your OS and/or router model, I'll try to walk you through setting up a shared printer or a USB connection on the router.
(Note: I have a USB printer connected and a wired network printer to a Cisco router. My only issue is that I get a printer error with every print job. The printers print the documents anyway. The error is due to the printers not responding to the software as fast as if it were a direct connection.)
Aug 10, 2013 | Canon PIXMA iP6310D InkJet Photo Printer
Tip
Set up a Wireless printer on your Router for use with a wired PC
First install the Wireless printer driver using the Wizard by connecting either the Ethernet cable to the router during the install process when asked this will set up your wireless laptop with the correct printer port based on the Wireless Node Name it will also use the printers inbuilt MAC address. This is standard install and will work for all your Wireless PC's however if you have a Wired (ethernet) PC connected to your Router this process will not work a wireless port will not work with a wired computer.
Follow my 3 steps below to set up standard IP ports for Wired PC's also connected to your Router.
STEP 1: Find your MAC address for the wireless printer (all types of Network Cards will have one so this is no different) this will either be found under the LCD control panel or may even be printer on the bottom of the printer or Print server if it is seperate set this MAC address with an IP address as a reservation in your admin panel of your router 192.168.0.10 in this example.
You can normally enter your Router this using 192.168.0.1 typed in your browser (not the search engine) as all routers are different check here for your make and model http://www.routerpasswords.com if you can't find the MAC address try using ipconfig /all from them command prompt it will be the physical address aka the MAC address
STEP 2:
Install the Printer as a USB printer port by connecting the USB cable to the PC you want the wired printer driver installed on when finished go to the printer driver properties for the driver you have just added, click the port tab and click add standard IP port as shown below, then disconnect the USB lead this is only required to make sure the correct inf file is used on the driver install and connect your Ethernet cable from you computers NIC to a spare RJ45 socket on the Router.
STEP 3: To check that the Printer has the correct IP address then test using the tracert OR ping command for the IP address that you have reserved on your router, this is a necessary step otherwise when the lease expires it may take another IP address and your Printer driver will not work unless your printer has the reserved address, it will throw a printer error.
c:ping 192.168.0.10
(this example shows a Standard TCP/IP Port for a Brother DCP-340CW)
Also check in your routers admin panel to see if the Wireless Printer is set up with the correct IP and MAC address, if you still can't find it eliminate your known MAC addresses from all your network cards the one left will be your Printer Server NIC in your Wireless Printer.
If you have setup the incorrect IP and or MAC address you will get this window when you try to add the TCP/IP port
That's it try a test print and you will see it burst into life.... Happy Printing
on Dec 02, 2009 | Office Equipment & Supplies
Installing SMCBR14UP printer with wireless connection
Let say you had Win7 then just select "add a printer" after look for 'devices and printer" in the Start section.If you find a printer there just delete it and then "add a printer" and follow the wizard.Note thta it will be wireless so try the IP you use in the Mac PC.
Jun 17, 2012 | SMC Barricade SMCBR14UP Router
How to hook up a wireless printer to a computer
Does the printer also have some "wired" interface (parallel-port, or USB-port)?
If not, then you need to purchase a router with wireless capability:
1. Connect cable-modem (or DSL-modem) to the 'WAN' (or 'IInternet') port on the router.
2. Connect one of the 'LAN' ports on the router to the network-port on your computer.
3. Configure the wireless-adapter inside the router:
* set an SSID -- the "name" of your wireless network
* encryption-level -- use 'WPA' or 'WPA2'
* a password for your network
4. Configure the wireless printer to connect to that SSID, using the password
5. On the computer, click "Add Networked Printer"
6. Print a "test" page: computer -> wired -> router -> wireless -> printer
Mar 18, 2011 | Canon Office Equipment & Supplies
The linkssys usb adapter does not connect automatically to the WLAn router. it always says "win xp manage the wlan" but this is not true
the problem may be caused by the installation of the usb adapter's WLAN software (WinXP already has a built-in WLAN). Ty uninstalling the adapter's WLAN monitor, unplug and replug the USB adapter to your computer and it will be installed automatically. Once installed, Go to Control Panel >> Network Connections >>Right click Wireless Network Connections and click View available wireless networks. Try manually connecting initially to the router and see if it will be automatic from then on.
Jul 05, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Can i connect my f4180 printer to a router and access it wirelessly
Your printer uses a USB interface and can be connected to a wireless network using a print server simular to the Linksys WPSM54G.
I have also found on the web several wireless routers that incorporate a USB print server function, that is they have a USB port that connects to your printer and allows it to be shared on the network.
Be careful not all routers with USB ports are for printers, these newer routers have USB ports for adding network shared disk storeage boxes and do not support printers.
They all incorporate a user friendly WEB based configuration program to help you do this so don't think you need a degree in computer science.
Jun 10, 2009 | HP DeskJet F4180 Inkjet Color All-In-One...
No wireless printer port for lexmark x4650
Your firewall for the wireless is blocking the port. Go into your firewall settings and add the port from the printer to bypass the router. What operating system do you have? It should be in Control Panel under Security Center.
Let me know.
Ray
Feb 03, 2009 | Lexmark X4650 InkJet Printer
Wireless printing
Check the printer's manual if the software of this printer already supports winVista. If it is, you may connect the printer directly to the PC and check if you'll be able to print.
Hope this helps!
Nov 12, 2008 | Compex NetPassage 28G Wireless Router...
MacBook and HP 4315
Hello Liz,
You can accomplish your request two different ways. (Both ways are a little technical and you might need assistance)
1) You can get a wireless adapter for your printer and then configure it as a node. Then print to it as a printer device. (node)
2) (cheaper way) You could connect the printer to a spare pc that is wirelesss. Then share out the printer.
Please feel free to ask any additional questions.
George
Sep 08, 2008 | HP Officejet 4315 All-in-One Printer
Asus WL-500W USB printer - Can't add printer
Fixed it, remember to install the vista driver for your harddisk, then select the port of the ip to the wireless devide, then it should work, you can check in the wireless web setup that the printer is located, under System.
May 12, 2008 | ASUS WL-500W Router (WL500W)
Linksys Wireless-G Broadband Router Logo
123 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
