Question about RCA F25674GY 25" TV
TV shut off while watching and wont turn back on. right before it shut off I noticed it dim from the sides and then stop, dim and then stop and then shut off. I would like to fix this myself!
    Top Expert:
  • RCA Master
  • 74,383 Answers
Hello
Your TV has problems in its horizontal output stage. You ypurself cannot rectify it. Consult a sevice technician.
Posted on Oct 17, 2010
My LED tv screen is dimmed on the right 1/3. After some use it eventually goes totally black?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 23, 2015 | LG 55" 7400 Series LED HDTV - 55LA7400
If my akai flatscreen 32in tv is moved or if the power goes out sometimes I plug it back in and the red light doesn't come on. Other times is when I'm watching it and I turn it off it goes from...
bad joint remove back panel with tv off check for any bad joints on power board also caused by thermal fault with tv on use a heat source over boards till tv shuts down then check suspect board
Dec 23, 2012 | Televison & Video
The TV has a section of it that is dimmed out and darker in brightness. Is this the Main Board that needs replaced?
Check the CCFL lamps used in the backlight section. These camps can cause this type of fault, as they are very like the flourocent tube lights that we use to illuminate our room. As it goes older, the ends of them will get burned, and the intensity will go low. Like ways is to the CCFL lamps to LCD tVs tool CCFL is the abbrivation of [Cold Cathode Flourocent Lamp]
Jul 12, 2012 | Vizio 55" M550NV Razor LED LCD HDTV, 1080p
I have a HP PL4245N plasma HD TV. sometimes while watching it just shuts itself off screen goes black and will not turn back on unless I unplug it wait 20 seconds and plug back. Then it works fine. it...
Hello
I thinks you may be right. All plasma and LCD panel tVs will have cooling fans at the top side. Plasma screens will heat up much more, and if cooling fans stops work, of has damaged, the set will overheat, and awill automatically shut down; because there is a overheat sensor fitted inside it, will sense the heat, and if the set overheats, it will send a signal to the main system control fo the TV; which in turn shut down the whole system. look fans for proper working. If not replace them. OK.
Jul 04, 2011 | HP PL4245N 42 in. HD-Ready Plasma...
Tv went blank, wont come back on.
If those green lights on the board are going dim, then yes it should be repaired. This is likely a bad main filter capacitor on the primary side of the switch mode transformer. Should not cost over $150 at the most. Easy fix
Aug 02, 2009 | Hitachi 70SBX74B 70" Rear Projection...
TV Turns Off Automatically While Watching
Stop trying to turn on the set. You are causing more damage. The hissing sound you are hearing is either a High Voltage Transformer on the SMPS (Switched Mode Power Supply) indicating a short somewhere in the set or some capicitors that have shorted out. Also there can be a CRT that is leaking cooling fluid onto the Main bd or the Power/Deflection bd or both bds. Have a trained Samsung tech troubleshoot the set.
Jul 15, 2009 | Samsung HCM4215W 42" Rear Projection...
TV shut off while on and wont turn back on,.. at all.
how long of a waranty does the TV have? If it is still covered I would contact the Manufactures about the problem.
Dec 18, 2008 | Televison & Video
Rca flat panel
the set has a fault ,requires service befor it gets worse.
Oct 27, 2007 | RCA 32F531T 32" TV
Tv shuts off while watching
replace EHT (extra high tension) transformer
Feb 07, 2007 | Philips TS3661C 36" TV
Hitachi 51F500 (Two separate problems?)
My guess is that the sound you heard was that of some High Voltage discharges that could have fed back and damaged some semiconductors including the microprocessor itself. Since it could be a very expensive repair, I would be very tempted to look around for a new HDTV by JVC or Toshiba. Hitachi has slipped a notch or two in recent years according to my experience.
Jan 25, 2007 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
