Question about Alton Alton 3 HP Air Compressor
New air filter assembly for alton at01205-11 - Alton Alton 3 HP Air Compressor
    New Friend:
My compressor fell over and the air cleaner was broken. where can I purchase a new one.. Alton AE01205-11?
Posted on Dec 08, 2013
Dimming lights while driving
could be bad ground or altenator
Dec 05, 2012 | 1997 Chevrolet Blazer
Alton 1/3 hp 2 gallon air compressor, building no pressure and sounds funny
Is your compressor a piston compressor? It may be that the valves in the head are shot?
Remove the Air Filter and quickly place your hand over the air intake hole, if you feel it **** AND blow, then theres your problem (It should only ****) these can be replaced.
Aug 18, 2012 | Air Tools & Compressors
Where can I find a metric lefthand bolt,8.8 stamped on sockethead screwcaphead.1 inches long,grade 8.it goes from piston rod to back of motor flywheel shaft.motor is 1 phase,3hrspower,120v,induction.
You may find a turnbuckle with that thread as they are all made in china now. That will get you the thread , then you will need to fashion something to take the place of the bolt head.
Or you can contact the manufacturer. Much of the new imported stuff has real cheap parts.
Dec 04, 2011 | Alton Alton 3 HP Air Compressor
I broke the air filter intake need to replace it where can i get one
I need to know the make and model of your air compressor
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 17, 2011 | Air Tools & Compressors
How to change the flter
Turn off the unit and unplug it. Turn the air purifier on it's side and unscrew the locking mechanism (turn counter-clockwise) on the base of the unit. Remove the base assembly from the unit. Remove the filter assembly and find the seam of the pre-filter. Carefully separate the fastener and then remove the pre-filter from the HEPA filter.
Discard the filter(s) being replaced. Then remove the new filter from the packaging and discard the packaging and plastic. Carefully wrap the pre-filter around the HEPA filter so that the ends meet. Fasten the ends together with the fastener.
Place the filter assembly in the air purifier and reattach the base. Then tighten the locking mechanism. Turn the unit right side up, plug it in and turn it on.
You can find a pdf of the manual here: http://www.honeywellpurifiers.com/product/0-90271-50150-4.html .
I hope this helps.
Oct 03, 2010 | Honeywell 50150 Air Purifier
Where is the cabin air filter located at and how do i get to it.
It will either be behind your glove box, or will be located under your hood by the firewall.
    Behind the Glove Compartment
  1. Open the glove compartment and remove all the items from inside of it.
  2. Remove the glove compartment assembly retainer screws with a Phillips head screwdriver. Refer to the repair manual for your specific year and model series BMW for the exact location of the screws or carefully look around the perimeter of the interior glove box assembly to locate the screws.
  3. Locate the lower trim panel retaining screws behind the glove box assembly. Remove the screws with a Phillips head screwdriver and then remove the panel.
  4. Remove the foot-well air duct.
  5. Loosen the retaining screws of the control module box to all you to lower it down.
  6. Turn the cabin air filter panel retaining knob counterclockwise to open the panel. Pull the filter removal tab outward to remove the filter.
  7. Use a shop vac to clean out any noticeable debris from the cabin air filter housing interior.
  8. Insert the new filter and reverse the order to reassemble the foot-well air duct, the trim panel and the glove compartment assembly.
  9. Under the Hood
  10. Open the hood and locate the cabin air filter housing. The housing is located near the cowling on the top section of the firewall. Some models place the housing in the middle of the cowling, on both sides--left and right--of the cowling or on the passenger side cowling. Removal of the cowling and placing the windshield wipers in the upward position may also be required on certain models. Some 7-Series BMWs place the filter housings on both the left and right side undercarriage of the hood.
  11. Release the cabin air filter duct clamp. This can either be released by unclipping the air filter duct by pressing a retaining lock with your fingers or using a flathead screwdriver to pry off a retaining rod.
  12. Lift the cover upward--or downward on hood-installed 7-Series BMWs--to reveal the cabin air filter.
  13. Remove the cabin air filter from the air duct. Vacuum the air duct with a shop vac.
  14. Insert the new cabin air filter(s) and reassemble.
Oct 16, 2009 | 1993 BMW 7 Series
Where is the fuel filter on a turbo desail
Your fuel filter is mounted on the rear of intake manifold, under air cleaner or on rear firewall.
Just a little hint on replacing it, remove your fuel tank cap to release pressure or vacuum in the tank. I'm sending you a diagram the fuel filter assembly so it will make it a little simpler for you to replace your fuel filter. Start by removing the filter element nut. Remove filter element by lifting straight out of filter housing. It is not necessary to drain fuel from filter housing when changing the filter element.
Installation, ensure mating surface between filter element assembly and filter housing is clean. Install new filter element by aligning widest key slot located under element assembly cap with widest key in filter housing assembly.
Tighten element nut by hand. Bleed air from fuel manager/filter assembly. Connect a hose to air bleed valve and place other end of hose in a container.
Disconnect fuel injection pump shutoff solenoid wire. Crank engine for 10 to 15 seconds. Allow starter to cool down for one minute between cranking intervals. Repeat procedure until clear fuel is observed at the air bleed hose.
Close air bleed. Connect injection pump shutoff solenoid wire and reinstall fuel filler cap. Start engine and allow to idle for five minutes. Check fuel manager/filter for leaks.9df1ca0.gif
Oct 03, 2009 | 1994 Chevrolet C/K 2500
Compressor
Unfortunately, the cost to replace just the compressor unit is not much different than replaceing the entire unit.
May 29, 2009 | Alton Alton 3 HP Air Compressor
1997 MADZA MVP
sounds like your altonator belt is loose and needs tightened. if you put a new belt on with the altonator it just needs re adjusted..
Oct 18, 2008 | Mazda MPV Cars & Trucks
Alton Alton 3 HP Air Compressor Logo
460 people viewed this question
Top Alton Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Alton Air Tool and Compressor Expert? Answer questions, earn points and help others
