Question about Whirlpool Duet Sport HT WFW8400TE Washer
What does f-28 mean? - Whirlpool Duet Sport HT WFW8400TE Washer
  • suellencarne Oct 17, 2010
    I tried all of above. Add a garment flashes, everything lights up as usual, but machine does not open and does not run. Unplugged it aalso and no go. Any ideas?
    Top Expert:
  • Whirlpool Master
  • 79,865 Answers
F28 Error Whirlpool washer.
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Posted on Oct 17, 2010
Maitenance code 28
Code 28 generally means that the driver for yourethernet controlleris not installed. I would recommend that you find the make and model of yourethernet card, go to thecard manufacturer's website and download the appropriate drivers.
Mar 26, 2014 | Brother MFC-8860DN Printer
Code 28 driver is not installed in my laptop, please tell me how i can install code 28 dricer and i have nothing any cd.
The Code 28 driver means that there is a piece of hardware installed on your computer, but the driver wasn't installed correctly. If you have recently installed a piece of hardware, then you may need to find the correct driver for it. These are often found on the manufacturers websites.
If this doesn't work, then remove any hardware you have recently added, and reboot the machine. If the code 28 error goes, then at least you know exactly what's causing it, and can re-troubleshoot from there.
Jul 23, 2011 | Microsoft Windows XP Professional
Washer comes up with 28 in the timer window and won't respond
Yes, it seems like the control board of your washer, check tham using a volt-meter.
Good Luck!!
Thanks
Jun 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Code 28 not installed
The drivers for this device are not installed. (Code 28)
Meaning that the device drivers for your device(s) have not yet been installed. Do you know what that specific device is?
To install the drivers for this device, on the Drivers tab, click Update Driver. This starts the Hardware Update wizard.
If this step will not work, try to locate the CD that came with your device.
Apr 16, 2009 | Computers & Internet
What is a fault code ct 28 on gsxr 600
c28 is the code for a problem with the secondary throttle valve actuator
hope this helps
regards bert31000
Mar 17, 2009 | 2001 Suzuki GSX-R 600
Error code F-28
It may be that the drain pump is not the problem at all. Error Code F-28 on the Kenmore HE2 means that there is a signal error between the Central Control Unit (CCU) and the Motor Control Unit (MCU)
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Code 28
Hi
I'm not sure that you can download code 28. This code means that the device drivers are not properly installed or not installed at all. Your best solution would be to download an updated driver for your audio device.
Contact your manufactures webiste and download the latest driver.
Aslo see this link
http://technet.microsoft.com/en-us/library/cc731268(WS.10).aspx
Keep moving forward
Feb 24, 2009 | Microsoft Windows XP Professional
Batter Not Charging
if your unit can charging battery from 0% to 28%, it's mean your battery is bad.
But if your unit can't charging battery at all, it's mean your motherboard is bad,
Jan 25, 2008 | Acer TravelMate 2300 Notebook
Whirlpool Duet Sport HT WFW8400TE Washer Logo
246 people viewed this question
Dan Webster
Dan Webster
Sal De
