SOURCE: HOW DO I ACTUALLY CONVERT A 3 in 1 CRIB TO A BED?
I emailed them for a copy of the assembly instructions. I'm sure they'll be able to help you with the conversion.
www.bassettbaby.com
You may contact your Consumer Affairs Representative at the following: [email protected]
Bassett Furniture Industries, Inc.
P.O. Box 626
Bassett, VA 24055
(276) 629-6000
1-800-308-7485
SOURCE: Bassett Crib
Call Bassett 1-276-629-6000 to obtain instructions and a parts list for model # 5926-0504 (look on the inside headboard - not the gold label).
Parts can be ordered from Products America 1-800-772-1041
SOURCE: Bassett Southampton Crib Directions
THE DIRECTIONS FOR BASSETT SOUTHHAMPTON CONVERTIBLE CRIB (model 5925-0521) ARE LOCATED *INSIDE* THE WARNING LABEL ON THE WIRE CRIB BASE. The warning label is an envelope that holds the direction packet. I was confused, too--I thought they hadn't included them with my crib! Hope that helps!
SOURCE: Unique Oak Treasures Crib - Full Bed Bassett Model 5542-0521
We have this crib as well. We bought it from Babys R' Us in 2005.
We also purchased the rails to convert it to a full sized bed. It did not come with instructions but I can explain to you how to put it together.
The rail conversion set should come with 2 pieces of wood that act as the bed frame. You do not need to purchase the extended frame. The set should also come with 4 long screws, the hex tool to tighten it and 4 metal pieces. You might also have some wood nail cover plugs.
Once you've taken apart your crib, the only pieces that you will need are the 2 longer pieces of the crib...the headboard and the footboard. The 2 shorter side pieces which served as a headboard and footboard as a crib and the metal grate to hold up the mattress can be put into storage.
On the sides of each of the new wood rails, you will see a circle indent on each end with a hole. You will insert one of the long screws into each and then insert it into the head board. You must use the special tool to screw/ tighten it in. The metal flat pieces can be inserted into it the circle befor eyou are done tightning so that it does not strip or damage the end of the circle. You do this with the other rail on the other end and then add the footboard using the same process. If you would like, I can send you a copy of what this looks like close up. ( the cricle indent with screws. The bed is extremely strong. We've all napt in it as a family along with our 2 large dogs. I highly recommend ordering the extra long/ tall bed rails from OneStepAhead for security because my son has rolled out of the bed and it is super tall!
http://www.onestepahead.com/catalog/product.jsp?productId=534602&parentCategoryId=85183&categoryId=85216&subCategoryId=86203
