Question about Husqvarna Viking 1
I'm trying to use my embroidery unit for the first time, and it's only sewing in vertical lines that are really close to each other (I'm trying to do a flower). But the image on the screen shows the little cross going to different parts of the flowers. Any idea what's wrong with it?
    New Friend:
  • 194 Answers
Did you let the machine do the entire embroidery? It souds like it is doing the foundation stitches and then should go back over those to do the fill stitches.
Posted on Oct 18, 2010
My Bernini 830 would not recognize the embroidery attachment. I re-attached many times, but it doesn't work.
I assume you mean a Bernina 830. If you have removed the slide-on table, I have two possible solutions. I've seen this with a couple of Viking embroidery attachment units. (I am also assuming it's not a hoop issue.)
You could have corrosion on the pins that send the signals between the embroidery attachment and the sewing machine. Remove the embroidery attachment and turn off the sewing machine. Unplug the sewing machine. Spray the pins with an electronic contact cleaner; one example is here: http://www.homedepot.com/p/CRC-QD-11-oz-Contact-Cleaner-02130-6/202262505 . Push the embroidery attachment into the sewing machine by lifting up the far side and then sliding it into the port. Remove the embroidery attachment. Repeat this a few times. (The friction of the insertion and removal will remove any dirt or corrosion.) Plug in the sewing machine and turn it on. Try connecting the embroidery attachment. If it works, remember to clean the contacts the next time the embroidery attachment isn't recognized.
Once I helped someone with two sewing/embroidery machines with an unrecognized embroidery attachment. In that case, the person swapped which embroidery unit went with which machine. The contacts were not the same and didn't mate. Once the correct machine and embroidery unit were paired, the embroidery unit was recognized instantly.
I hope this helps. If it doesn't, you may need to talk to your Bernina repair technician at your local shop.
Aug 19, 2017 | Sewing Machines
My machine does not recognize that the embroidery unit is attached. It keeps saying attach embroidery unit. Has anyone had this problem
What make and model of sewing machine do you have? I have seen this problem with a Husqvarna Viking Designer I (or similar older Viking machine). In that case, the problem was corrosion on the contacts between the embroidery unit and the sewing machine. The solution was to use an electronic contact cleaner to clean the contacts; this is one product: http://www.amazon.com/CRC-05101-QD-Electronic-Cleaner/dp/B000CCMLD0 . Make sure that the machine is unplugged. Spray the contact cleaner on the contacts. (In some cases, you should then connect the embroidery unit to the machine and remove it a few times.) Allow the product to dry before you plug in the sewing machine again.
In another case, the solution was actually easier. The owner had two similar embroidery machines. She managed to mix up which embroidery unit went with which sewing machine. Neither embroidery unit could be properly seated on the machine that she attempting to use it with. Once the embroidery unit was paired with the correct machine, both pairs worked.
I hope this helps.
Aug 03, 2015 | Sewing Machines
Janome
Sounds like your embroidery unit may have a bad motor or broken drive belt. Get that unit into a repair shop.
Cheers,
Kelly
San Diego, CA
Jul 30, 2014 | Janome Memorycraft 9700 Computerized...
Artista 165 embroidery unit will not communicate with my sewing machine.
Did it ever work ? Have you had the firmware updated in the machine - if-so, the V4.04 firmware will not communicate with a V3 embroidery unit and you'll have to get them updated to the same version. Failing that, I'm afraid one of them has a fault on the serial interface. Note also that a 165 sewing machine will not work with a 180/185 embroidery unit because the earlier unit has a 2MB memory internally, whereas the later unit has a plug-in 4MB memory.
Feb 09, 2012 | Bernina Artista 180
How do I find out the embroidery time on my Viking Designer 1 sewing machine?
Hi there, If your trying to find out how long it took you to embroider something, You need to go to your touch screen menu- touch Set- then down at the bottom left of this screen and touch More- three (3) times you'll get to where it says Running time:(It's the 3rd Selection) There it will actually show you the total running time (Sewing and Embroidery If you haven't zeroed it out by hitting the zero (0) next to that selection.) You can do this on the touch screen with the embroidery unit on or off. You need to touch the zero (0) to zero out your time before you start an embroidery project. Once you've done this and you've finished an embroidery you can check how long it took by the touch screen menu- Set- touch More 3 times and there you will see how long on the Running time it took to embroider your design. I hope that helped. The total time your machine has ran (Embroidery and Sewing) is kept in Memory on the Service Screen that your Technician gets into when he services your machine. So your not actually wiping out that. The Set menu is just for you to keep track of how long your machine sews or embroiders something pretty much. I hope that helped you out with your question. Happy Sewing!! Kathy
Nov 19, 2010 | Husqvarna Designer I
Babylock Ellure Embroidery Unit Malfunction
You need to make sure that the embroidery arm is able to move freely be sure that it has no obstructions like a wall behind your sewing table or fabric that may be stacked nearby. If all is clear you probably have thread wrapped somewhere inside the embroidery unit it only take a little bit to jam up the works. You can try to take off the cover by flipping the unit over and removing the screws to the embroidery arm. I would take it to the shop where you bought it they should be able to help you for free if it is new. If you have the original packaging you can send the machine to Steve's at www.stevessewandvac.com just send them an email they can help.
Jul 27, 2008 | Baby Lock Ellure
Pfaffa 7570 Creative Fantasy Embroidery Unit does not move
Try turning the machine off, removing the unit and then placing it back before turning the power on again.
Apr 08, 2008 | PfaFF Creative 7570
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
