Question about Cameras
How can I set my nikon D300 to take pictures in really dark lighting? I do not want to use a flash.
    Brigadier General:
  • 11,967 Answers
Set the ISO to a higher number and put the camera on a tripod because the shutter will remain open for an extended period of time. You may have to experiment with the ISO setting and also exposure compensation to get the exact result you're looking for.
Posted on Oct 16, 2010
Intermittent dark images
Sounds like they are a little out of sync. Try adjusting the timer settings.
May 06, 2012 | Nikon Speedlight SB-800 TTL Flash
My nikon d3000 is great. but now when i view my pics there is a flashing in certain areas of the pic. also my flash won't flash. is there something i can do to fix it
This flashing is often an indication that those areas are 'over exposed'. This could be because you have manual settings such as 'EV +1'etc., or 'spot metering' when you took the picture centred on a dark part of the scene. You could check this by setting the camera to automatic to see if it solves the problem. If it does, have a good look through the menus and user guide to see what the various manual settings are.
The flash settings include one where the flash is off, and there is usually a button to toggle between the automatic/off/forced flash/red eye suppression etc.
Dec 15, 2010 | Nikon D300 Body Only Digital Camera
Nikon D300 flash wont pop up in Auto mode
Hello. In automode, the flash will only pop up when the light conditions require it to pop up. Joe
Mar 31, 2010 | Nikon D300 Body Only Digital Camera
REAR FLASH PRB ON NIKON D300
If your doing what I think you are then, It sounds like the flash is set too act as a commander for the off-camera CLS flash setup. Check setting e3 and put it in TTL mode. It's called rear or 2nd curtain flash sync.
Oct 21, 2009 | Nikon D300 Digital Camera
Shutter is lagging with sb-800 flash attached. flash goes off, 3 sec later shutter goes
Have you checked the flash mode?
I have no problems with the combination D300 SB-800.
I assume you don't have a picture if the flash goes off before the shutter open(?)
If you do check the menu e2 Flash shutter speed you can set it at a few seconds in spite of the fact that the flash sync (e1) is something reasonable like 1/250
The flash shutter speed is set to 1/60 in my camera...
Aug 21, 2009 | Nikon D300 Digital Camera
Nikon D60 is suddenly taking very dark pictures
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Jun 22, 2009 | Nikon D60 Digital Camera with 18-55mm +...
All my pictures have a dark straight shadow along the top of each picture. Or the left side if I shoot vertical I have the d300
u need to be aware to make ur fingers far away when u use Flash. try to turn off the Flash if the problem doesn't appear then the problem as i said to u above.
Jun 07, 2009 | Nikon Cameras
Images are coming out REALLY dark
first GET TO AUTO MODE WITH FULL AUTO
if this doesn't work try going to manual and setting the exposure up to +1 or +2
Feb 04, 2009 | Nikon D40x Digital Camera
Nikon SB 800 fires but pictures reamain dark
make sure your white balance is set to "flash" on both cameras
Oct 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
