Question about Samsung HL61A750A 61" HDTV
Good Evening I have a HL61A750A1FXZA and it keeps telling me to check Fan #3 and the nswitching Off can someone please tell me what needs to be done please. Thank you Bill
  • Samsung Master
  • 15,633 Answers
There are fans in back of the unit that keep it cool. If one of them wont start it says that you need to check the fans. In order to do this you need to take the back off the unit and see how bad the dust is. YOu should get a vacuum cleaner hose and a brush and clean out the unit and then see if you can spot the fans. They are black and about 3 inches square. See if you can turn them by hand. You can then place the back on the unit and try it and see if the message goes away. If it does not then you need to figure what the interlock is that is on the back of the set that prevents it from starting with the back off. There is usually a tab that has to trip a switch. You need to defeat this and start the set while watching the fans. IF one of them wont start then that is your problem fan. You can take it out and replace it very easily. IF all the fans start then you have an issue with the fans sensor that detects if it is running and that could be a big problem .
Posted on Oct 17, 2010
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
I have a samsung Samsung HL61A750A1FXZA what is the part 4 the # 3 fan is it BP31-00025A
Replace the fan with a new one and check. The the voltage to the Fan. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 18, 2014 | Samsung Televison & Video
Can someone please tell me how to bypass a heater core in a 2000 chevy camaro temorary?
Look at the fire wall by the passenger side you will see two 3/4 hoses you need to cut the hose going in and the one coming out take a piece of 3/4 metal pipe and install in the hoses clamp both hoses tightly you are done check your fluid
Oct 31, 2014 | 2000 Chevrolet Camaro
2008 impala got in this evening and ac won't turn
Someone will need to check the fuse for the blower, then the blower motor and the resistor.
Aug 09, 2012 | Cars & Trucks
WHAT DOES THE ERROR MESSAGE F76 MEAN?
1/ check overheat stat 2/ check fan esp the little hose at the fan area for pinhole best of luck
Sep 28, 2009 | Noritz 6.9 Gallon Residential Tankless...
Fan not working
The Problem that you are having is that the heat sink is full of dust therfor the processor can cool down quick enoufgh so in result by safty it shuts the computer down. You need to clean all the dust out of the heat sink and this problem will be solved.
Good Luck
May 04, 2009 | HP Pavilion dv9000z Notebook
I need to replace the cooling fan and heatsink on my Gateway ML6720. I'm having trouble finding the part. If I can find it, can you tell me how to replace it?
The best thing you can do is replace the fan itself with a like kind of shape and size. I usually do this by going to a computer store with the old fan and matching it up with the ones they have in stock, or measure the size in milimeters and buy one on line. The fan is held on by 4 screws and it is much easier than trying to remove the heat-sink and take the chance of damaging the motherboard. You can just screw the new fan to the old heat-sink and you are done, plug it in and insure the fan is blowing in the right direction and you are done. Good Luck, RAC
Apr 20, 2009 | Computers & Internet
Samsung HL61A750A 61" HDTV Logo
334 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
