Question about Lexmark X2470 All-In-One InkJet Printer
Ink cartridge I am low on ink and have not been using my printer. When I plugged it in and turned everything on the cartridge zipped across so fast I banged into each end of the printer's walls also something popped out , it looks like a guide. it is about 1 ft long, and it is a flat clear strip with a single hole in each end with arrows at the end. in very small print it says: cav.134 1pm320434 01. 06 I cannot find where to connect it please help thanks Marilyn
  • Anonymous Oct 02, 2008
    Did anyone figure out where it goes? I have the same issue
I have the same exact problem, don't know where to connect it. Any suggestions?
Posted on Jul 02, 2008
I have changed both low ink cartridges in my HP Officejet 4315v and I continue to get a message "cartridge error". I can not even align the new ink, can you please help?
The problem is either of these two things:
Often the ink cartridge is damaged where the connection takes place with the printer (this is usually the issue).
OR the printer needs to be reset. To reset the printer turn it off. Turn the computer off. Unplug everything. Wait one minute, plug everything back in. Turn the printer on first and then the computer.
All printers made in the last 7-8 years have the feature that they completely reset when all connections are removed.
Apr 08, 2011 | Computers & Internet
Error message, cartridge error "cartridge
I'm not sure what ou mean by fairly new. Is it a color cartridge and have you been printing photographs? Is it an HP cartridge or a generic brand? Cartridges are used up very fast if you are printing photos. I print a lot of photos and have found that although they cost more, the cartridges made for each particular printer usually last longer and do a better job. Are the cartridge lights blinking, as they do when yo have low ink?
It could also be a problem with the cartridge. Try removing the cartridge and very carefully use a damp paper towel to gently clean the printer head of the cartridge. Do you get any ink when you do this? If you do, try putting the cartridge carefully back into place. Check the socket where the cartridge goes when you do this. Does everything seem to be in order?
Do a power reset (turn the printer off with the off button, unplug it for a full minute, then plug it back into the wall socket.) turn the printer back on. If you still have the message,
go to this site http://h10025.www1.hp.com/ewfrf/wc/product?product=1119598&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20â
You will find a video here for your printer as well as frequently asked questions, a manual download, etc.
Good luck to you.
Jan 11, 2011 | HP Officejet 6310 All-In-One InkJet...
Refill lexmark 37xl ink
I own a Cartridge World ink refilling store and we do not refill the Lexmark 36 and 37. The reason is that your printer turns off the electronics on the cartridge when the ink gets low, so you can't reuse the cartridge. Your printer will only function with an electronically functioning cartridge. We NEVER recommend Lexmark printers. They are poorly made, don't accept refills a lot of the time, and across manufacturer their ink costs the most and is designed to clog the cartridge if you don't use it fast enough. We recommend HP printers that take integrated print head cartridges and Canon printers that take tank style cartridges.
Mar 01, 2010 | Lexmark X4650 InkJet Printer
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
I have a Lexmark X4650 I refilled the cartridge and now I cannot get the printer to recognize the cartridge it prints black only and tells me Color is low . any suggestions on how to bypass this prob get...
I own a Cartridge World ink refilling store and I can't refill the Lexmark 36 and 37 cartridges. Your printer deactivates the electronics on this cartridge when the ink levels get low. Your printer needs a black and a color cartridge with functioning electronics to print. I NEVER recommend Lexmark printers. They are poorly made, don't accept refills easily, and have the most expensive ink across manufacturers and it is designed to clog your cartridge unless you use it quickly. If you keep this machine you are stuck buying Lexmark brand ink (the return program cartridges are a little cheaper though).
Dec 24, 2009 | Lexmark X4650 InkJet Printer
"incompatible ink cartridge"
Printer needs to be reset:
1. Power OFF printer
2. UN-plug power cord at wall/surge protector
3. Turn ON printer (w/o power cord plugged in)
4. Plug in power cord
5. Turn ON printer
(This will reset the printer)
Sep 01, 2009 | HP OfficeJet J4580 All-In-One Laser...
Cartridge holder won't move when i press button to change ink
Hi, it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge poswition when you press the button.
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ink cartridge full, but printing as if out/low
I have found using 3 r d party inks in Canon printers will mess them up fast but the ones with the contacts don't work period
Dec 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Ink Cartridge Error
on your cartridges there is a chip that detects if the ink is low. The chip on your yellow cartridge is bad. You should return the cartridge for a new one(if you still have your receipt) or visit a Cartridge World in your area and they can put a new chip on for you
Aug 12, 2008 | HP Photosmart C6180 All-In-One InkJet...
Lexmark X2470 All-In-One InkJet Printer Logo
71 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
