Question about Denon AVR-3300 Receiver
How to do a hard reset on a denon avr 3300 - Denon AVR-3300 Receiver
  • 163 Answers
Hold the following AUTO button and PCM button, and plug
the AC cord into the outlet.
Posted on Oct 17, 2010
Testimonial: "worked like a charm thanks for the help"
5 Suggested Answers
mattvierra
  • 74 Answers
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF] AVR-3300/1 3.3E*
Posted on Jul 22, 2009
  • 54 Answers
SOURCE: No Audio Output
OK.....there was a strange thing with this receiver......make sure that you are not on " headphones only ". Had a customer with the same problem. As for the fan, it doesnt run constantly. It only runs when the amp is hot enought to require extra cooling.....HOWEVER....there was a problem with the fans on these units, so much so, that Denon released a modification for the 3300 including a new fan and some upgraded circuitry.
If the unit is not flasning " protection ", or " overload".....you should be OK., however I would spend a few bucks and get the fan mod installed.....these are good sounding units and ecen though it does not have Dolby PL II, and DTS-ES, I have owned a couple of them and find that they sound better than most new ones. Get out your owners manual and look in the headphone section. If memory serves me well, there is even a way to do it with the remote. Good luck.... Rob
Posted on Apr 22, 2008
Bulldog AV
  • 52 Answers
SOURCE: Current value of a Denon AVR-3300
about $150
Posted on Nov 24, 2009
vegetav
SOURCE: Denon AVR-3300 component channel switch burnout?
hi there, i don't have a solution unfortuantely, but i may have the same problem. I have a denon 2802 av receiver, i bought it second hand and I can't seem to get the component video in / out working. Are you supposed to just plug it in and it works? Because I can't find any buttons or settings to select component in / out as my input / output sources?
Posted on Jan 23, 2010
Can i hook up a power amp to my denon avr-3300 with out a pre-amp
Yes. Your receiver has the required pre-out connection terminals needed to go to an external amplifier. That would make your receiver operate as the pre-amp/processor.
Feb 21, 2012 | Denon AVR-3300 Receiver
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
Dear sir, The denon AVR 3300 receiver quits after playing a while; somtimes it quits after an hour,sometimes after 2 hours! Can you tell me how the sleep timer functions..... Thank you Cees van...
There is no sleep timer on the 3300. You are experiencing an "over heat" shut down. The 3300 is notorious for over heating at almost any volume level. It must be vented constantly with an external fan pulling air completely through the cabinet. Don't use it at all until you do this. The internal fan is week and will start to make noise from too much heat. Replacing the Denon fan will not solve this either. See my other posts about this issue.
Oct 03, 2010 | Denon AVR-3300 Receiver
Nov 12, 2009 | Denon AVR-3300 Receiver
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Denon AVR-3300 Receiver Logo
3,237 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
