Question about Waterway Executive Spa Pump 4hp Impeller 3104190
I can't remove the impeller on a 4hp Speck pump...I've worked on several 3/4 to 3 hp pool pumps but this one is a first...also, how is the seal plate attached? maybe I'll figure that out if I'm able to remove the impeller?!
  • 35 Answers
If the shaft seal has been leaking for some time the stem on the impeller has likely spit due to corrosion on the motor shaft. This makes it near impossible to un screw the impeller. You can try and isolate the armature of the motor and use a channel lock on the impeller. The only other way to get it off is by breaking it. Use a flat head screwdriver and a hammer and break apart the area around the center of the impeller until you can pry off the everything but the stem. You'll have to remove the ceramic part of the seal and pick out as much of the stem as you can. Then you can get the wetend off the motor and remove the metal cup seal.
Posted on Oct 17, 2010
Super 11 pump clogged impeller how to fix
Remove the 6 bolts holding the motor mounting plate to the pump housing. Back the motor assembly out. Remove the diffuser and you'll see the impeller. Using picks and wire run through all of the impellers vanes to clear out the debris.
Mar 19, 2013 | Hayward 3/4hp Super Pump Inground Pool...
I have a speck 90 series pump with a broken impeller how do i remove the impeller off the shaft
You'll need to remove the back plate off the motor. Take a pair of channel locks and hold onto the bolt that goes through the motor. With your other hand, unscrew the impeller off the shaft.
Jun 14, 2011 | Speck Pumps Pool & Spa
MY E90 III SPECK POOL PUMP IS LEAKING BEHIND THE IMPELLER. WE JUST REPLACED THE HOUSING O RING. PLEASE ADVISE A FIX
Thank you for posting your question here on Fixya.com.
Replace the mechanical seal located behind the impeller along the motor shaft. Half is on the impeller and half is in the seal plate.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Apr 28, 2011 | Speck Pumps Pool & Spa
Trying to replace a 4hp motor on a speck pump but can't remove the impeller, also, how is the seal plate attached? I've worked on several 3/4 to 3 hp pool pumps but this one is a first!
Id be happy to help if you could tell me what model speck pump you are working on.
There is just not enough information here.
Once you have the model, you can contact me @: adamh@newconceptchem.com for further assistance. I will give you the website for all the speck manuals incase you need it as well.
http://www.speck-pumps.com/html/usa/download_pool.html
thanks,
adam
if this post has helped you, please take the time to vote positively for me on this site.
Oct 16, 2010 | Speck Pumps Impeller 1hp Full1 12hp Up...
Im getting a loud buzzing noise when the pump is running
could be an obstruction in the impeller, or the bearings going out. You can split the pump in two be removing the large clamp or 4-6 bolts holding the two halves together. (not the 4 bolts holding the motor to seal plate, but the the bolts holding the seal plate to the seal plate housing. once you remove the clamp or bolts, the motor with seal plate and impeller and diffuser can all be pulled back away from the pump. You need to remove the diffuser (plastic housing that goes around the impeller) usually by a series of 3 to 6 small screws. Now you can easily try and spin the impeller and check for obstructions that might have bound it. If you do not see anything stuck in the impeller, then the noise is likely coming from the motor (probably the bearings) you can replace the motor, or have it rebuilt. if your not gunna rebuild it you can deal with it as long as the noise doesn't bother you and the motor is not getting too hot
Sep 15, 2010 | ADVANTAGE Waterway SVL56 Pool Pump...
Pump will not draw water in from skimmer.the pump seems to work fine except that need help?
ON A HAYWARD #1 BROKEN IMPELLER OR PLUGGED ,#2 SHAFT SEAL #3 LID SEAL #4 TANK CRACKED.. LOOK FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY USE YOUR ZIP IN YOUR SEARCH .. YOU WANT THE IMPELLER WITH THE BRASS SHAFT ! ASK FOR IT HECK DEMAND IT !... YOURS IS PLASTIC = PLASTIC THREADS (JUNK) . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 23, 2010 | Hayward 3/4hp Super Pump Inground Pool...
How do you separate the motor from the housing?
Remove the bolts in the back of the plastic strainer housing, that will take the basket assembly off the pump.
The diffuser/ should be visible, this simply pops off with a little twist. The impeller should be now be visible
Remove the metal cap from the back of the pump.
Remove the rubber cap on the back of the motor under the metal case, (may not have one)
You will see a the back of the motor shaft and a slot that a flat head screw driver fits into.
Now is a tricky part that is somewhat dangerous.
You need to hold the impeller and turn that motor shaft with the screwdriver counter clockwise. It's best to hold the impeller with a rag for a better grip. You need to make sure you're using a beefy screwdriver that fits that slot well, or you might slip and jab yourself with the screwdriver.
It is tough to remove. Be careful.
Once the impeller is removed, you will see the seal plate, the bolts for this are on the back out the motor mount plate and can be removed with little effort.
You should now be down to a just a motor.
You may need to buy a replacement seal, as they tend to fall apart once tampered with.
Jun 25, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Speck Pump Model E90 has very little pressure when vaccuming pool
while I can not personally vouch for this company, they do stock speck parts.
http://www.poolpartsonline.com/m-44-speck.aspx
You will most likely need part # 2920741271 - O-RING (strainer tank) It's the o-ring that sits underneath the strainer lid and is most likely cause of your weak vac pressure. Make sure when you replace it, you use a good silicone based lube. It will help the lid seal better and prevent the o-ring from deteriorating faster if you used a petrol based lubricant.
Jun 16, 2009 | Speck Pumps Impeller. 3/4 Hp, S.F. 1.0,...
Tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
May 28, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
How do you change a pump seal on a hayward 1hp pool pump
The seal is located behind the impeller. Once you remove the impeller it is fairly obvious how to replace it. Basically, unscrew everything, replace it and put it back together again. There is a decent diagram on page 11 of the Hayward owners manual found here if you need it. http://www.haywardnet.com/products/Manuals/pdfs/Manual113.pdf
May 13, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Waterway Executive Spa Pump 4hp Impeller 3104190 Logo
553 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
