Question about Garden
How do you prime the Wagner procoat 2800 - Garden
2 Suggested Answers
  • 885 Answers
SOURCE: Wagoner Procoat Airless Sprayer without
One cause for this is that one or both of the check balls in the piston are frozen in place. This can be caused by drying paint on the check balls or seats or, as is the case many times in our area, if you did clean the machine well with water without any airless conditioner in it, sometimes the water dries and leave behind minerals that 'lock' the check balls in the seats. Set the machine up in water and turn it on to prime. Using a hammer hit the pump head where the piston is working fairly hard. You are trying not to break anything but knock the check balls loose. If they come loose and water starts cycling through the system, let run a while to wash anything out before switching to paint. If this doesn't work, you may have to take the head apart to see why the check balls won't free up. It could be because of peices of dried paint that won't come loose by themselves.
Posted on Jun 16, 2011
My Wagner Xtra Painetr Pro will not spray paint like it is not drawing paint and it was never used. Do you put oil in it somewhere? It is like it will not get primed.
no. tell me more are you using cup or paint hose? if using cup perhaps your paint is too thick, try adding flotrol to pain and mix
Oct 29, 2017 | Wagner Air Tools & Compressors
Remove and Install prime/spray valve Wagner paint crew airless paint sprayer?
Was the unit purchased new or used? The price of a new is about $125-170. This unit is for homeowner occasional use, not for large jobs.Was the unit working on the previous use? If so were the cleaning instructions followed and not shortcut. If paint is failed to be totally removed on cleanup it will dry inside unit.There are very few replacement parts for this unit. If the unit is not working take wrench and try to remove prime/spray valve. You will have to remove knob to access this part.
Apr 18, 2017 | Wagner Air Tools & Compressors
My procoat won't prime
The inlet valve is probably stuck. It is a flat poppet type, so you need to free it up. A Graco dealer should be able to supply a special small plastic bottle with a special top filled with their Pump Armour to do this job. Otherwise you can unscrew the inlet valve from the cup side to clean it out, but be careful not to lose the small spring. You should always flush Pump Armour through the ProCoat after use otherwise the passageways corrode
Feb 18, 2014 | Wagner Tools & Hardware - Others
Won't prime
You either have a stuck ball valve, or a leak in the paint suction
Feb 09, 2014 | Wagner SprayTech Wagner Airless Paint...
Unit won't prime,
YOU HAVE A STUCK INLET BALL
Have the unit in water, pressure relief valve turn the machine on and tap with a hammer at the inlet ball, This frees it up 90 of the time.
Otherwise the machine need to be disassemble
Jan 29, 2014 | Wagner SprayTech Wagner Airless Paint...
Will not prime
Most of the time when a unit will not prime it is because of a stuck inlet ball, I would put the intake in water turn the machine on to bleed. Then tap the machine where the paint comes in. 90% of the time this will get it going. Sometime you can stick a screw driver into the inlet ball and free it up. If this doe not work you need to take the machine apart and cleanor you have worn out packing.
Joe
Jan 23, 2014 | Wagner SprayTech Wagner Airless Paint...
Wagner paint crew model 770
It doesn't take much residual paint to dry out in hose and block it.Have you lowered the paint pressure?
Wagner 770 Owner Manual Page 8
Nov 27, 2017 | Air Tools & Compressors
I have a Wagner Procoat That i cannot get to prime?
had the same problem i sprayed wd40 where the suction tube goes and primed three times hope this helps
Aug 27, 2011 | Garden
Garden Logo
378 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
