Question about Garden
How to thread a bobbin for montgomery ward sewing machine model 188
dontbother10
  • 2220 Answers
SOURCE: 2.0 Cubic Inch Montgomery Ward gas chain saw, 10 inch cutting bar
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 3 months old use up in a 4 cycle engine. HTH
Lou
Posted on Oct 26, 2009
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 1116 Answers
SOURCE: thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
Posted on Mar 13, 2010
I am looking for a metal bobbin holder for a Montgomery Ward UHT J1980 sewing machine.
If you have the original bobbin case that came with your machine, you can take it to a sewing repair shop and check if they can get a replacement. Otherwise, searching the internet:
Bobbin Case Hook And Race Wards Sewing Machine Model UHT J1980
http://www.manualsonline.com/support/montgomery-ward/sewing-machine
Try taking your machine to a sewing repair shop and see if they can help. Perhaps they will try some bobbin cases that they have in stock.
Apr 23, 2016 | Sewing Machines
How to thread an old Montgomery Ward sewing machine model 30 ? e
Search the internet for your machine make & model & threading instructions. You may not find your exact machine, but a lot of similar machines will have the same threading sequence.
Just a hint: be sure to RAISE the presser foot BEFORE threading the upper thread so the tension disk will allow the thread to seat properly.
Video Demonstration of vintage Montgomery Wards Sewing Machine built in...
Dec 05, 2015 | Montgomery Ward Sewing Machines
Problem sewing
You may need to tighten your upper thread tension or loosen the tension on your bobbin. I don't know if you are using a newer model sewing machine or an older one; but if it is like mine, there is a little screw on the bobbin you turn to loosen the tension.
My Kenmore sewing machine bunches up on the bottom if I am using a different type of thread in the bobbin than I am using on the top part of the sewing machine.
Dec 28, 2014 | Montgomery Ward Sewing Machines
Need a manual for Montgomery Ward Computer 2001 Sewing Machine
I can be reached at thesewinggirl21@gmail.com. I have a copy of the manual for the Montgomery Ward Computer 2001 Sewing Machine.
Feb 29, 2012 | Montgomery Ward Sewing Machines
Help with an older sewing machine
There are lots of men who sew...it is not gender specific.
Perhaps this will help--unfortunately not free:
Wards 1984 Instruction Manual
Montgomery Wards Sewing Machine Instruction and Service Manuals
Montgomery Ward did not make their own machines, so it was most likely manufactured by a sewing machine company with Montgomery Ward's name on it.
However, most machines thread similarly. Just be sure to ALWAYS RAISE the presser foot when threading the top thread--this allows the thread to seat in the tension disk. Set the top tension to about the midway point to start and then tweak from there.
threading older sewing machine Google Search
Understanding Thread Tension Threads
Bobbin tension is usually the last thing to try to adjust...be sure to mark the screw setting BEFORE making any adjustment...
Bobbin Tension How and Why Tension is Adjusted
Needles are probably the least expensive resolution to a lot of sewing machine problems--change them often!!! About every 8 hours of sewing, and be sure to use a needle that is compatible with the thread and fabric. Be sure to install the needle with the flat part facing the correct direction. Most machines have the flat part facing the back of the machine, however, some machines with the bobbin loading from the side will have the flat part of the needle facing the harp (throat) of the machine. AVOID old or bargain bin threads! Use fresh, good quality sewing machine thread (generally, Coats & Clark is not one of them...)
All About Needles
May 13, 2017 | Singer 7422
Garden Logo
181 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
