Question about KitchenAid 450 Watts KM25G0XWH Stand Mixer
Have a 450 watt commercial kitchen aid KM25G that is hitting both the bottom of the bowl and the side as well?
SOURCE: broken mix master
http://www.fixya.com/support/t636606-kitchenaid_ksm90_stand_mixer
Posted on Sep 20, 2008
mdsaeed67
  • 849 Answers
SOURCE: Kitchen Aid Mixer
you should replace that part with new one
Posted on Oct 31, 2008
SOURCE: Can the Kitchen aid accessories fit the Wolfgang puck stand mixer
If you happen to have a friendly toolmaker with a small metal lathe it should not be too difficult to modify KITCHEN AID accessories that fit on to the front powwer outlet. However Puck Stand Mixer accessories are occasionaly offered on the Web. Meat grinders are very common and original Puck pasta maker have also been seen. Get searchin'!
Posted on Dec 22, 2008
JonThibodeau
  • 4 Answers
SOURCE: Kitchen aid 300 watt counter mixer model ksm90
Here is a link to the instruction manual:
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KSM150PSOB_Use%20and%20Care.pdf
Quick summary:
Tilt back the head of your mixer. Look at the joint between the head/body of the mixer. A flat-head (standard) screw will now be visible. Turn this screw counter-clockwise to raise the attachments, clockwise to lower them. Don't turn the screw too much, it is pretty sensitive.
Posted on Jan 24, 2009
ricardok45
  • 135 Answers
SOURCE: I an looking for the intructions on my Kitchen Aid
Hi. Goto kitchenaid.com. Click on the Customer Care button, click on find manuals, in the search window, enter k45sswh. this page will show the operating manual and farther down the page the parts manual. Download both these files.
Go to mendingshed.com and locate their FREE kitchenaid service manual and download it. This manual will greatly assist you or a repair person should your mixer ever need repair.
A word of caution...Do not overload the mixer with too much bread or cookie dough or it will cause damage to the transmission. Use the recommended capacities found in the manual.
If this solution has assisted you, please rate it. Good luck! ricardok45
Posted on Apr 07, 2009
How do I fix a kitchen aid mixer that possibly shorted out?
Buy a new one quick. Or hide. Spent . electrical engineering. And supply of new diodes resistors and capacitors are needed.
Apr 17, 2016 | KitchenAid New Professional 5.5 QT...
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
Kitchen aid model kg25. vibrates and beater hits bottom of bowl
Your worm gear is no longer seated and that is more than likely because the housing cover is probably the old style plastic and it has cracked which allows the worm gear to jump up during operation and turn out of sync. The worm gear turns the drive gear that works the planetary gears which in turn drives the beater. If the worm gear is not turning true then of course it is pushing the planetary out of true as it turns, which causes the beater to slam the sides of the bowl. The question is this...does the beater hit the bowl in the same place on the bowl every time? Or does the beater hit the bowl in different places every time? If it hits the same place then it is probably just a planetary gear of which there are four gears involved and it could be any one of them. It it hits a different place every time it is most likely the worm gear and cover. In either case parts will cost between 30 and 50 dollars. and it takes about an hour to fix.
Dec 30, 2014 | Food Mixers
What rpm is the 4th setting on the Kitchen Aid KM25G?
There is no internal adjustment for the speeds of your mixer and the Service Manual does not give any r.p.m. figures.
Apr 29, 2014 | KitchenAid Food Mixers
Kitchen aid stand mixer blades do not reach bottom of bowl
go to youtube type in ajustment on kitchen aids and it will show u step by step hope this helps
Sep 28, 2012 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Mine is a K5-A Hobart Kitchen Aid mixer and the back bowl pin broke off so I can't click the bowl in place any more. Please help!
sounds like you need a new bowl lift cam, on the n-50 which is a hobart table-top model pull top off pedestle, you will see the cam you have to remove one cotter pin and remove one split pin install new cam reassemble
Dec 31, 2009 | KitchenAid K5SS Heavy Duty Commercial...
no there is no adjustment . worn hinge on the base , no parts made , not that i have ever seen ...... sorry i wish i had better news
Jan 05, 2009 | Hobart A200 Stand Mixer
Kitchen aide mixer
was the bowl snapped in to place.....push down on the back lip of the bowel until you hear it snap
Dec 30, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
KitchenAid 450 Watts KM25G0XWH Stand Mixer Logo
59 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
