Hi, I have a WHIRLPOOL washing machine, Model # LSQ9549LW0 with worn agitator dogs. I have the agitator off and I can clearly see the agitator dogs right down the center. But they are under a plastic cage that I can't figure out how to remove. I have looked at the schematic at searspartsdirect.com and it is what I have. How do I access the dogs to replace them? I have seen some of the other instructions on this site, and they don't match my machine. Thanks a lot.
  • 7 Answers
SOURCE: replacing dog agits
Should be a plastic insert that you have to turn counter clock wise till you can pull out. Then remove top section of agitator. then with a socket 9/16 deep socket remove the nut. When you remove nut the bolt may come with it thats ok, then you can remove agitator. good luck
Posted on Feb 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: Removing old dogs to replace them
Take pliers and pull it hard. It will come loose.
Posted on Apr 06, 2009
Jimster
  • 240 Answers
SOURCE: Agitator dogs worn
Ok, here is how ya do it. Remove the protective cap on top of the agitator (remove softener dispensor if optioned). Down in the hole you will see a plastic cap with a square fitting built in to it. Take a 1/2 extension and stick it in the hole. Unscrew the entire plastic button, then the spring. You can now remove the top and replace the dogs. A long pair of needle nose pliers can also unscrew that cap if its not to tight.
Posted on Apr 26, 2009
  • 67 Answers
SOURCE: Bottom of agitator works, top half does not. Dogs
remove the agitator by removing the agitator bolt in the center then the pieces will all come apart, don't just buy the dogs, get the whole cam kit, it doesn't cost much more and it comes with all the replacement parts for the internal agitator
Posted on Aug 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have an Inglis Sterling washer
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
The agitator on my Whirlpool washing machine isn't working properly. It is moving a little bit but not fully, any help?
You may have worn out agitator dogs. Those are replaceable parts. Not sure which model you have, but if you google for:
whirlpool agitator dog replacement
you should get plenty of hits.
Apr 01, 2015 | Whirlpool Washing Machines
Upper portion of Whirlpool agitator not turning
Your agitator dogs are worn out. Remove the agitator and seperate the upper section from the lower section. There are 4 small teardrop shaped pieces that are the agitator dogs. They have either come apart over time or at least the teeth have worn off them.
Post back with any questions. Please verify the model number. I couldn't pull up a parts list for it. I know the last digit should be a 0 (zero) instead of an o.
Thanks/Mike
Jan 07, 2008 | Washing Machines
Whirlpool top load washer. Agitator seems to be wearing out. It barely turns now. if you apply pressure to top of agitator during wash cycle it will agitate. Sound like the agitator is stripped out so...
This is usually the agitator dogs have worn out or broke. These are very inexpensive and easy to replace. Here is a video this will walk you thru checking and replacing the agitator dogs . You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 17, 2010 | Whirlpool Washing Machines
The agitator on my whirlpool saws800jq2 top load washer is not spinning. where is my problem? motor? clutch?
Sep 17, 2010 | Whirlpool Washing Machines
The agitator is loose and "clunks" as it is washing. How to fix?
You may have a worn agitator cam assembly, worn agitator dogs, or a loose agitator bolt.
Whirlpool uses a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by either worn agitator dogs, a worn agitator cam assembly, or a loose agitator bolt. The following link explains what the dogs are and how to access and/or replace them. It also explains how to access the bolt and tighten (if necessary):
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number for the dogs are included in the link provided. You can purchase replacements at pcappliancerepair.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs for about $11 or $12.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you aren't sure, or have additional questions about this repair, please post back with your complete model number (located on a nameplate along the wash tub opening under the lid) and let me know. I hope this helps you.
NOTE: DO NOT overtighten the agitator bolt. This can cause damage to the plastic, or restrict the agitator movement. Tighten until snug only.
Feb 03, 2010 | Roper RAS6233KQ Top Load Washer
The top part of the aggatator does not turn
Washer has trouble agitating... Check the agitator dogs inside the top of the agitator, they are bad for wearing out, sometimes the agitator may only agitate one way when the dogs are worn out. This is an instruction sheet that came with the last parts I ordered for a Whirlpool/Inglis style direct drive washer agitator. If you need to replace your agitator dogs, please see this link for some repair aid.
Replace the dogs its a easy fix for you
Dec 28, 2009 | Whirlpool Washing Machines
No agitate and no spin
ok,,you need agitator dogs ,,the top auger move booth direction,,worn agitator dogs,,,i need you to fill unit on smal use a poy or bucket i have to know if this washes,,,onthejob
Jan 16, 2009 | Whirlpool Washing Machines
Washer doesn't agitate
I would like to raplace the damaged part if possible
Dec 20, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Broken Washing Machine Agitator
probably just what is known as agitator dogs just worn ..with no brand or model i assume it's a whirpool or kenmore ..1st remove softner dispenser (without brand can't say how it would come off ..some twist off some just pull off ) if agitator has cap underneath pull it off in center of agitator should be a bolt 7/16 if kenmore/whirlpool..remove it pull up on top half ..whole thing may come out if so just pull up sharply on top part..center part of top half comes out dogs are on it( 4 )again i'm assuming kenmore/whirlpool whirpool part # 80040 replace them and reassemble ..if any other brand will probably have to replace entire agitator..good luck
Sep 11, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
