Question about Kenmore 24 in. 15932 Built-in Dishwasher
I just installed a new garbage disposal and my dishwasher will not empty
  • Kenmore Master
  • 43,501 Answers
Did you pop the "knockout" out of the connector before hooking up the hose?
DishwasherProblems - Water will not drain out
heatman101
Posted on Oct 22, 2010
Dishwasher not emptying out water
If you recently replaced your garbage disposal make sure the "knock out" plug was punched out to allow drain water into the disposal. The guy who replaced my disposal forgot to do it and my dishwasher would not empty. It's an easy fix. Just remove the drain hose from the dishwasher that attachs to your garbage disposal. Look inside with a flashlight and you will see if it is still there.
If it is, take a hammer and screw driver or punch and knock it out. TURN OFF POWER to your disposal and you can retrieve the "knock out" plug (piece of plastic about the size of a dime). Replace your drain hose to the disposal and try your dishwasher again. Worked for me! Good luck.
Oct 05, 2014 | Dishwashers
Dishwasher LD-1420T1 tripping power in the house?
Okay, this could be tricky because depending on who installed it, they might have wired into it. Check your garbage disposal and if you have anything else plugged in nearby, check that wiring too. Some installers have a nasty issue when it comes to hard wiring. They don't like doing it. So instead of hard-wiring your garbage disposal, they'll cut it in to your dishwasher. If your garbage disposal or anything else is wired to your dishwasher the load on the washer and the current the washer is using is too high. That's going to trip your breakers. You should probably contact an electrician and have them check the breaker box to make sure it's wired correctly. You may need to upgrade the breaker or have the dishwasher circuit upgraded. If it's an old house, it could be anything but first, check to see that nothing is wired into your dishwasher. You can tell if you have a few switches in the same outlet and turn them off. If your garbage disposal won't work and the DW won't either, then you have a wiring issue. That's the easiest way to start.
Apr 06, 2014 | LG LD-1420T1 Dishwasher
When dishwasher is emptying it is backing into sink
there is probably nothing wrong with Dishwasher itself.
Your Sink drain is stopped up or your Garbage disposal is clogged.
usually, dishwasher drain is connected to the Garbage Disposal, but if the dishwasher empties the water into the Garbage disposal, if its clogged then water will come out of the sink. Same if sink is clogged between sink and sewer.
If you fill up your sink and then water drains away, then you know your sink itself is not the problem. If its only the Garbage disposal side that does not drain, its the garbage disposal that is clogged.
Dec 22, 2013 | Dishwashers
Dishwasher ide1005 wont empty
Make sure line from the dishwasher to the drain is clear.
If you have a new garbage disposal, be sure to remove the plug where the
drain line enters the disposal. This can be done by tapping it into the disposal and retrieving from the disposal with a magnet.
Sep 16, 2012 | Washing Machines
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
Water will not drain. I did have a new garbage disposer installed a couple of days ago, but don't know enough about dishwashers to even see where it connects to the disposer.
Hi Ruthp53, I am JK. I see that you have installed a new garbage disposal and now are having problems with your dishwasher (model FGHD2433KF) draining. I would recommend checking for blockage at garbage disposal and the drain. Also, new garbage disposables normally have a plug that will need to be taken out.
Hope this helps!
Sep 09, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
My dish washer leaks water
The hose from the air gap on top of your sink to the garbage disposer is plugged.or kinked probably.Unless you have a new garbage disposer and the plug wasn't knocked out at the dishwasher drain connection
Jun 23, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Wont drain water out, have replaced filter. machine beeps and wont empty out old water. Whirlpool dishwasher, model adg7440
New garbage disposal? It's happened many times in my career- customer installs a new disposal then the dishwasher won't drain so they buy a new dishwasher to find the disposal didn't have the knock out knocked out. Check the easy stuff first.
Ken
Jan 08, 2010 | Whirlpool 24 in. ADG7540 Built-in...
New Garbage disposal, washing machine and dishwasher won't work.
Does not sound like these problems are directly related to the disposer. Grinding sound is most likely the impeller on the washer's pump. The washer gets to the first pump out and is unable to pump due to bad impeller or an obstruction. Bad impeller means replace pump motor. (not very hard) Check water supply to dishwasher. Valve turned off or line kinked? Filter screen at solonoid valve plugged?
Aug 15, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Kenmore 24 in. 15932 Built-in Dishwasher Logo
44 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
