Question about Fujitsu ScanSnap Manager
Scansnap manager for Mac has started to crash after every scan. Scans are completed and put in the appropriate folder but the program then crashes. Restart...another scan...crashes... Restarted computer...restarted scanner...relaunched Finder....reinstalled software....still crashes after every scan. Scanner and software are 2 weeks old. Running Snow Leopard. No additional updates available.
How to recreate a new folder for my scansnap manager to be able to scan. I tried without success. Where do I put it, etc.
Right click on your desktop. Choose new and then folder. Name it Scansnsp And it's done. When you setup your scanning be sure to tell it to send your scans to the desktop folder named scansnap. I hope that helps
I’m happy to help further over the phone at https://www.6ya.com/expert/tami_f8d2d553d5094045
Mar 31, 2017 | Computers & Internet
Scanner will not pull the paper all the way through & scan. Scanner says not valid folder to save image is selected . Set the save folder for the scanned image data. I don't know what to do
Try to scan by using the quick menu as I described below:
Check for the ScanSnap Manager icon on the taskbar.
5d5f1b3.jpg Right click the mouse button over that ScanSnap Manager icon.
Select “Scan Button Settings” from the Right-Click Menu.
2344c41.jpg Select the “Use Quick Menu” check box (it must be checked).
Load the document in the ScanSnap which you want to scan.
Pres the “scan” button on the ScanSnap.
Click the “Scan to folder” icon in the quick menu when scanning is completed.
The “Scan to Folder” dialog box appears.
Check the scanned image in the “Scan to Folder” dialog box.
By clicking save buton, save the scanned data in a specified folder which you select chancing the filename as you want.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 09, 2010 | Fujitsu ScanSnap Manager
I can not scan to folder now, I am using scansnap s510m, please guide how to solve this problem. I am using macbookpro
Click and hold down the mouse button over the ScanSnap Manager Icon in the Dock menu and confirm that Quick Menu is checked.
load the document you want to scan
press the scan button
when scanning is complete the snapscan quick menu appears
place the curser on the scan2 folder
click it in the action list
a preview window appears
You can change the file name and the folder you want to put it in. You can also resize it here by dragging the lower right corner
here is the manual
http://www.fujitsu.ca/pdf/scanners/manual/operator/s510/S510M_Owner_P3PC-1942-01ENZ0.pdf
Dec 31, 2009 | Fujitsu ScanSnap Manager
My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
May 26, 2009 | Fujitsu ScanSnap Manager
ScanSnap Manager - Error!! You do not have a write authority for the installation folder.\nMake the selected folder writable.
Normally this error will only come up when you have already tried installing the Scansnap Manager.
Go to C:\Windows\SSDriver. Right click the folder and select properties, select the security tab, then make sure "Users" has full control.
Repeat these steps on the PFU folder in Program Files.
Put in the Scansnap disk and navigate to the Tools folder. Run the SSCleaner tool and delete all of the Scansnap components.
If Scansnap Manager is not listed in the Cleaner tool, Delete the contents of the SSDriver and PFU folders manually.
Restart the computer and reinstall the components.
May 14, 2009 | Fujitsu ScanSnap Manager
I have and love Scan Snap S500 on a pc.  I am transferring to a Mac.  I downloaded the Scan Snap for Mac S510M.  The program installs fine, but does not open.  The icon shows a big red line through it.  ...
Check out:
http://forums.macosxhints.com/showthread.php?p=527817#post527817
Thelatest Fujitsu ScanSnap V2.2 L11 drivers have been patched by me to work withS300, S500, S510 and fi-5110EOX/2/3 PC-based scanners for the MAC. Noneed to buy a new scanner. Just apply the patch and then send me aChristmas card! ;)
Hope this helps!
Jan 16, 2009 | Fujitsu ScanSnap Manager
Driver scansnap
There should not be any problem installing that sofware on that OS and version. My guess is you have a botched (corrupted) install. Try uninstalling if you can otherwise let me know and we'll "clean out the registry." Good luck!
Jul 22, 2008 | Fujitsu ScanSnap Manager
Internet connection crashes-mouse freezes
I am assuming you are running windows.
Make sure you are running an antivirus program as well as anti spyware program like 'windows defender' . Run complete scans with both antivirus and antispyware delete any virus or spyware detected by both programs and check/compare the difference.
I hope it helped!
Apr 26, 2008 | Computers & Internet
Computers & Internet Logo
113 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
